First G alignment done, what to look for?
Old Apr 17, 2008 | 04:15 AM
bigc's Avatar
Wings Nation
that sounds about right...and yes, only one car (i think)
Old Apr 17, 2008 | 09:30 AM
releasedtruth's Avatar
It was $119 here in Tucson as well. Right way to start out the new ride I think, especially with these 'country' roads we've got. They also got grease on my door panel and drivers window, was not pleased.
Q45tech's Avatar
"i think the specs are pretty close..."
The nominal [NORMAL] numbers are there for a reason, anything outside shows an error either in construction [or reconstruction after a repair] or wear in the rubber isolation in suspension or the camber increases caused by stress on shock towers [they bend inward with age road stress] or worse with increased tire and WHEEL WEIGHT!
A brand new reference alignment is important to see what you bought and how it changes with time to determine WHEN you must replace or repair components to return to as new conditions.
As Infiniti found out very few of dealers had calibrated and accurate alignment machines to set to spec, so be very careful in chosing who you use to set a base line or what you use to make corrections.
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
