how many times normally can you turn OEM rotors ???
Originally Posted by JOKER
Do you think that only your pads wear out?
Do you think that your rotors stay exactly the same as they were when they were new?
2. No
What is your point?
Originally Posted by Jeff92se
Why don't you just get the point? Because right now you aren't making any type of technical sense.
the quicker you answer the Q the quicker you'll realize the point.
Do you get your wheels rechecked every time you change tires?
Do you get your engine inspected every time you change your oil?
Do you get your injectors cleaned and flow balanced every time you change your gas?
Is there constant wear on all of these items? yes. Point?
Uneven runout, as I stated previously
What about hot spots that will bulge out and yet contain small groves that will be considered OK by dial indicator?
Originally Posted by 68_GT
just wondering if I'll be in a set of rotors when I replace the pads for the first time this week or if they should still be thick enough to turn at least once. They seem fine
I'm replacing the pads b/c they are squeeking and putting off tons of brake dust. The car is female driven and 38K miles.
thanks
I'm replacing the pads b/c they are squeeking and putting off tons of brake dust. The car is female driven and 38K miles.thanks
2. YES
3. YES (every 60k or so miles)
4. NO
what about minor surface cracks?
Still not making sense here
What about them?
Nothing!
those are great to have on your rotors.
So maybe later they could develop into a large cracks and maybe even a half of your rotor falls of while you driving on the highway and you hit a semi truck carrying some kind of toxic waist and spill that **** all over the freway killing 100 ppl or so.
Cracks are not that important.
