BBKs really make you stop that much shorter? Find out
Old Apr 24, 2008 | 12:00 PM
Jeff92se's Avatar
Red Card Crew
http://www.zeckhausen.com/testing_br...rmance%20Model
Results are pretty interesting.
Old Apr 24, 2008 | 12:12 PM
MixturePinoy's Avatar
very good find jeffy' too bad they didnt get to finish up on the last set though
Old Apr 24, 2008 | 12:17 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I would like to see what the stock brakes do with Slotted rotors and aftermarket pads.
Good test though, the BBK's stay much cooler.
Old Apr 24, 2008 | 12:22 PM
redlude97's Avatar
Probably worse than stock
Old Apr 24, 2008 | 01:57 PM
Jeff92se's Avatar
Red Card Crew
In what terms? Brake dist or temps? Brake dist probably won't do anything.
Brake temps is a tough one. Drilling a bunch of holes might allow the heat to dissapate faster but it won't PREVENT the rotor from heating up. It actually might heat UP faster and HOTTER because you just took out a bunch of mass that was helping the rotor absorb heat at a slower rate.
Imagine heating up a piece of scrape steel. (original rotor). Note how fast it heats up and how fast it cools down. Then note what it looks like after.
The imagine heating up a piece of wire. ie.. 18 ga for instance. (slotted/drilled rotor) Note the same as above.
What differences do you observe in between the two?
Old Apr 24, 2008 | 03:59 PM
helldorado's Avatar
The rotors in a BBK are often times heavier than the stock ones. So even if the pad swept area is larger and it has a higher friction coefficient, you're trying to slow down more reciprocating mass. So you don't always get more stopping power even if you feel the additional brake torque.
But larger rotors and much larger calipers are more effective heat sinks with sustained heavy braking.
Besides, it doesn't matter how great your brakes are at slowing the wheels from spinning, its still totally depending on the tires.
It is a good article though. I've read it before.
Old Apr 24, 2008 | 04:00 PM
helldorado's Avatar
WTF, post orgasm of like 10 double posts, lol.
Old Apr 24, 2008 | 04:21 PM
Jeff92se's Avatar
Red Card Crew
helldorado. Thanks for the input and good points.
You check the weights of the oem 14" Akebono oem rotors for the G37 sport? Someone said 28lbs! Holy moly!
Old Apr 24, 2008 | 05:07 PM
Locksmith's Avatar
Good find man!
Old Apr 24, 2008 | 10:42 PM
Beebo's Avatar
interesting...
Old Apr 24, 2008 | 10:49 PM
GLuXuRy's Avatar
who cares if they stop you better than stock
BBK IS BALLIN
Old Apr 24, 2008 | 11:11 PM
Sandman's Avatar
+1
That's the key point right there. Other than looks, of course .
Old Apr 24, 2008 | 11:20 PM
helldorado's Avatar
I didn't weigh my 14.25" AP Racing rotors but I would imagine they're just slightly lighter than that with the 2 piece hat. Either way, the full assembly was substantially heavier than stock.
Old Apr 25, 2008 | 01:26 AM
Jeff92se's Avatar
Red Card Crew
BBK IS BALLIN
I care at least. If I'm going to spend that much $ for brakes, it had BETTER perform superior to stock in SOME way. Most believe BBK = way shorter brake distances but it's not as true as most would believe.
I guess it's one of my pet peeves regarding all these mega big/20 piston bbk kits you see. All bling and no real data.
Only Stoptech and Racing Brake seem to offer any real explaination to their kit sizes, bias and tech ingo. I know AP makes high quality products also.
But the rest of these kits? Who knows? They're shiny I guess.
Old Apr 25, 2008 | 01:34 AM
redlude97's Avatar
Exactly.
