Z suspension swap questions
Old Apr 26, 2008 | 04:28 PM
delsap's Avatar
Would the springs sag more because of weight or something?
Old Apr 26, 2008 | 04:33 PM
Gsedan35's Avatar
Originally Posted by delsap
Yea thats it I knew the drop would be more because the pro-kit is for the 350z but I didnt think it would be a full extra inch.
Eibach 350Z progressive springs 1”/1”
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
Eibach 350Z progressive springs when run on G35 sedan 2"/2"
Thankfully you have more spring rate then typical G35 aftermaket drop springs, shorter shocks vs oem G35 shocks and firmer shock valving vs your oem sedan shocks. Keep in mind that even with those things in play, you still don't have a lot of shock piston stroke on bump.
Old Apr 26, 2008 | 05:04 PM
delsap's Avatar
Anyone have any expiriance with something like this before because a 2" drop would cause some problems..?
Old Apr 26, 2008 | 05:22 PM
delsap's Avatar
Dont mind the last post i did not see the latest response but let me make sure I get what your trying to tell me. It will drop my car a full two inches but because the shocks and springs are stiffer than stock I won't have alot of give or something? just kinds lost me at the end and if i did drop it a full two inches would i be gambling with speedbumps and so on?
Old Apr 26, 2008 | 05:29 PM
Gilley's Avatar
Let me try to clarify. If you install the Eibachs, you'll have a 2 inch drop on your sedan, but the pistons won't have much stroke (the distance they can move in and out) before bottoming out.
The 350Z shocks will work, but their life will be shortened.
you will definitely need front and rear camber kits unless you don't mind wearing out tires really fast.
Old Apr 26, 2008 | 05:58 PM
delsap's Avatar
Okay thanks for the help I just wanted to be sure to know exactly what you were trying to tell me. I think I am just going to wait for a set of all oem springs/shocks 2" won't work with the roads around here.
Old Apr 29, 2008 | 08:05 AM
n15m0's Avatar
z suspension
So let me get this straight...a full OEM Z suspension (springs + struts) into a G35 sedan will be a 1" drop yeah???
Old Apr 29, 2008 | 09:45 AM
naughty240's Avatar
yup.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
