Spc Rear Arm Diy??
Old Apr 27, 2008 | 01:17 PM
fairwaywiz's Avatar
Spc Rear Arm Diy??
is there an SPC rear arm DIY thread here... i found the threads for the A arm and everything for the front....
however i couldnt find anything for the rear with pictures and everything. (yes i am a visual learner)
any help would help me a lot
Old Apr 29, 2008 | 12:57 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
If you're just replacing the rear arm, its self explanatory... Remove the stock arm, and replace it with the SPC...
-GP-
Old Apr 29, 2008 | 11:36 AM
06BLACKG's Avatar
Its really not that bad. If your doing toe bolts as well there is a diy for elongating the slot floating around. Good luck
Old May 1, 2008 | 09:08 PM
PTownG's Avatar
it's very easy. The bolt at the wheel comes right out, the bolt at the chassis I had to unbolt the sway bar mounts to drop the bar enough to get it out.
Took about an hour to do both sides with a rachet and a breaker bar.
Old May 1, 2008 | 09:23 PM
TurboDreamzG's Avatar
The rear arms are pretty easy like they said it's self explanatory. Here is a picture of the arms....click to view larger, http://www.sfxperformance.com/parts/EIB572050k.htm basically just remove to the two bolts holding the arms on and install the new ones back in. If minor adjusting is needed to get the car to alignment shop then do so.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
rezendvous420
May 31, 2020 01:26 PM
Daniel k.
Nov 3, 2015 09:52 AM
TreeFiddy
Aug 10, 2015 06:50 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
