View Poll Results: What setting would you choose for stillen sways
medium front and medium rear
50.00%
medium front and firm rear
20.00%
soft front and medium rear
6.67%
other
23.33%
Voters: 30. You may not vote on this poll
Stillen Sway Bar Setting
Old May 5, 2008 | 12:19 PM
Nismo G's Avatar
Originally Posted by kenchan
which means your recommendation is crap?
hahaha sorry i should restate that. I meant to say he won't find any race car drivers with the set up he has lmao. Im an idiot ill change it.
-Sean
Old May 5, 2008 | 01:44 PM
Klubbheads's Avatar
Originally Posted by 5150DS
I have med front and med/hard rear. Thinking about changing to hard/hard.
Great way to start Med/hard. When u go hard/hard look for understeer, if there is none then u steering is going to be much more direct. Good luck. BTW get ready to get after market endlinks if ur running stiff and drive the car hard into turns. My rear endlink snapped not too long ago.
Old May 5, 2008 | 01:47 PM
Klubbheads's Avatar
Originally Posted by OCG35
you guys don't get too much understeer with stiffest front settings?
depends on the tire size difference from back to front. If the tire size is equal (back and front) then u should get no understeer, if the front tires are much narrower than the rears than u might see some understeer at the limit. This is very general though, spring rates etc have a lot to do with it as well.
Old May 5, 2008 | 05:59 PM
kenchan's Avatar
yep, depends on which springs and damp setting you're running, along with
the tires, offset, etc. etc. it's not a one shot deal.
the poll is just a generic baseline comment. from there you'll need to
experiment. also depends on the kind of roads you're driving tightness
of turns and what you need, etc. for chicago roads on my setup med/med
is about ideal, +26mm offset front and rear 245/35/19 275/35/19 RE050
Polepositions.
Old May 6, 2008 | 06:36 AM
jimmykce1's Avatar
Polepositions.
I currently on stock 18" sport rims with Z/coupe spring setup.
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
