LCA problem/fix
Old May 7, 2008 | 12:47 AM
fast04G's Avatar
LCA problem/fix
ok so all these problems with our Lower Control Arms bushing failures. What i have, and heard is that the bushing on the bottom middle of the car,subframe, break. The makes a popping noise/make your car pull the either side thats broke. there is nothing that helps to keep this bushing centered, and from moving excesively(spelling??). im going to take some measurements of this and use some conduit piping. cut the pipe to fit over the mount and leave an opening for the LCA bushing. this should help to stabilize and keep the bushing from moving too much. Also should help tighten up the suspension. My good friend is Friggin awesome suspension expert, he helped my with this idea, and is going to help with the fabbing. sry the description of what im talking about and doing is vague. some of you know what im talking about. when i do this, prolly next month, ill do a DYI, or atleast post some pics on what im talking about.
bignacio
Steering & Suspension
Jul 22, 2015 04:40 AM
soundmike
Feb 14, 2013 03:51 PM
whoisthis
Sep 29, 2011 01:12 AM
LCA575
Jan 6, 2008 06:20 PM
LCA575
Dec 8, 2007 01:16 PM
