Question about springs and lowering.
Old May 11, 2008 | 02:59 AM
officerdbag's Avatar
Which springs would give me the biggest drop?
I was going to get some tein S tech springs but recently I've been seeing "350z tien H tech" in peoples sigs.
So do the 350 H techs give a bigger drop than the G35 S techs? I'm looking to get the biggest drop w/ springs without having to go with coilovers.
I'm planning to lower my G w/ M45 19" rims so I don't want to spend my rim money on coilovers...
Thanks!
Old May 11, 2008 | 03:00 AM
srsly's Avatar
H-techs drop less than s-techs and buy less I mean the car sits higher on H-techs
I have M45 19"s on factory springs and Joker has them with H-techs so check out pics of both of our rides and see for yourself if you like it
Old May 11, 2008 | 03:06 AM
srsly's Avatar
Old May 11, 2008 | 03:12 AM
Ahh.. Man it was both of those coupes that make me want to get the M45 rims.
Both are hot but i'm definitely gonna lower.
So, basically are the G35 S techs the lowest drop you can get? What about the 350Z s techs?
Also, check this out:
http://www.finishlinewheels.com/INFINITI/M35/2007/
300 bucks a rim brand new isn't that bad.. Those are real OEM too not replica.
Old May 11, 2008 | 03:24 AM
srsly's Avatar
remember $1200 for the wheels isnt bad but what about tires? I know the OEM bridgestones go for ~$245 a piece...your best bet is to find someone selling used
Old May 11, 2008 | 04:29 AM
lniivedl's Avatar
You can drop more with Tanabe's than with Tein..but at that point youll be needing camber kits front and back..
Old May 11, 2008 | 05:03 AM
Thanks!
Tein S. Techs it is.
Old May 11, 2008 | 10:14 PM
Beebo's Avatar
Tanabe's is the lowest you can go i believe...
Tanabe DF210 G35 coupe - (drop 1.7 front/ 1.3 rear)
Old Jun 10, 2008 | 09:19 PM
Spdu4ia's Avatar
Just to bump this thread... What is the benifit of running 350z springs on the G?
What is the lowering difference between the G35 S-techs and teh 350Z S-techs? Are the Tanable's still lower than any of the Teins?
Old Jun 13, 2008 | 09:08 AM
Beebo's Avatar
Any aftermarket spring for the Z will lower the G half an inch more then a aftermarket G spring will
yes thetanable's are still lower than any of the Teins
Old Jun 13, 2008 | 11:58 AM
Calvin's Avatar
Overglorified Altima
Tanabe DF210 & Eibach Sportline
Old Jun 13, 2008 | 01:15 PM
5150DS's Avatar
Also, the s-tech Z-springs have a higher spring rate than the G springs.
Old Jun 13, 2008 | 01:20 PM
Jeff92se's Avatar
Red Card Crew
Hope you're factoring in camber correction costs with those springs
Old Jun 13, 2008 | 01:53 PM
Texasscout's Avatar
Before:
After:
And it's settled about another third of an inch.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
