Question for DIYers on SPC rear toe bolt install
Old May 18, 2008 | 05:11 PM
Konsole's Avatar
The instructions for the 72050 talk about making the bolt hole larger for the toe bolt:
8. Mark area to elongate hole with template provided and use #85126 Rotary file or equivalent to elongate slot. Check to make sure hole is the right size by placing the new bolt with a cam on the head into the hole, it should rotate 360 degrees.
Has anyone done this DIY? If so how?
I have my front and rear SPC kits on the way, just brushing up on research. I want to install them myself and then get it all aligned. I installed my Eibach pro kit already.
Thanks for any help.
instructions here: http://www.spcalignment.com/PROD_DIR...txt&cmd2=72050
Old May 18, 2008 | 05:42 PM
jjyellow's Avatar
You need to use a dremel
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
youngdip631
V36 Brakes, Suspension, Wheels & Tires
14
Jul 29, 2015 11:28 AM
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
