Interpreting the alignment numbers...
Old May 23, 2008 | 10:48 AM
nooooorb's Avatar
Originally posted this on the Suspension section but got no replies. Hopefully, moving it to this section garners some good response.
To all the alignment gurus... I need your help in interpreting the alignment numbers? The first set is the old alignment numbers and is for reference.
Done by Gdup35sedan last year (I'm dropped on 350Z H-Techs):
FRONT LEFT
Camber = -1.5
Caster = 8.4
Toe = 0.06
SAI = 5.4
Included Angle = 3.9
FRONT RIGHT
Camber = -1.5
Caster = 8.3
Toe = 0.04
SAI = 4.8
Included Angle = 3.3
FRONT
Cross Camber = 0.0
Cross Caster = 0.1
Cross SAI = 0.6
Total Toe = 0.10
REAR LEFT
Camber = -2.0
Toe = 0.06
REAR RIGHT
Camber = -2.1
Toe = 0.06
REAR
Cross Camber = 0.1
Total Toe = 0.12
Thrust Angle = 0.00
Done by earlier today (still on the same 350Z H-Techs):
FRONT LEFT
Camber = -1.2
Caster = 8.7
Toe = 0.02
SAI = -0.7
Included Angle = -1.9
FRONT RIGHT
Camber = -1.7
Caster = 8.7
Toe = 0.04
SAI = 7.0
Included Angle = 5.3
FRONT
Cross Camber = 0.5
Cross Caster = 0.0
Cross SAI = -7.7
Total Toe = 0.06
REAR LEFT
Camber = -1.6
Toe = 0.15
REAR RIGHT
Camber = -2.3
Toe = 0.10
REAR
Cross Camber = 0.7
Total Toe = 0.26
Thrust Angle = 0.03
My main concerns are the FRONT SAI and Included Angle. Why such a difference in the range between left & right?
Much appreciated...
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
