Maintenance Question - please help!
Old May 27, 2008 | 03:27 PM
petea21's Avatar
I'm new to the forum and have a maintenance question. At what mileage should the brakes be replaced for a 2004 G35 coupe? I have a general distrust for dealers and don't know if they're telling me the right thing.
Old May 27, 2008 | 03:57 PM
TopTech's Avatar
I don't think there is any mileage spec. on the brakes. They need replacing when they have worn down enuf.
Cassman's Avatar
Are they making noise? If not, have them show the pad to you. The OEM brake pads/rotors on the front last less than 30k.
Old May 27, 2008 | 04:04 PM
LjN_728's Avatar
I replaced my rears at 33k and the fronts about 40k. I'm not an aggressive driver.
Old May 27, 2008 | 05:10 PM
petea21's Avatar
Thanks for all of the advice.
Old May 27, 2008 | 05:45 PM
JZ's Avatar
JZ
G35 Coupe KY0
Im picking up a set of CD/SLT rotors on Thursday... My fronts and rears aer starting to sqeak sometimes and I dont like that...
Old May 27, 2008 | 06:13 PM
NyQuiz's Avatar
From my experience so far the fronts should be good for about 16-30k
Old May 28, 2008 | 09:59 AM
G35fromPA's Avatar
Pads and rotors each have a minimum thickness that is specified in the Factory Service Manual. If they are near that minimum, then it's time to replace them. Ask for measurements, and compare to the FSM specs for whichever coupe model you have. There is no hard and fast rule for mileage as everyone uses their brakes differently.
Old May 28, 2008 | 10:40 AM
culi's Avatar
I just changed my rear (05 coupe) around 53000 miles. Just check the front and it was still good. The front hardly worn down at all.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
korfak
Jul 20, 2015 12:10 PM
