uneven coilover suspension?
uneven coilover suspension help adjusting
I have some stance coilovers and i'm trying to adjust the rears. I adjusted to perch under the spring to raise it and didi the samething on the d/s and the p/s but i have to adjust it so much more on the p/s to raise it up a small amount. Anyone have any comments on why that is ? thanks
If you have the rear springs in the oem location, here is a how to for adjusting your height. http://www.my350z.com/forum/showthre...highlight=spin For a true coilover setup in the rear, you will adjust height the same way you adjust the front.
Do not adjust height by adjusting the seats the springs sit on, only the oem style rear setup adjust's height that way.
