caliper painting anyone?
Old Dec 23, 2008 | 05:26 PM
Texasscout's Avatar
Originally Posted by bythabay
did you paint the inside of the calipers as well?
Yes I did. I took them off (needed to replace the rotors anyway) and scrubbed them with a degreaser and a wire brush to get them back down to the original silver cadmium coating. Found some rust spots and scrubbed some more. Rinsed with clean water and let them dry. I painted the brackets separately and then the calipers as they hung from the lines.
Old Dec 23, 2008 | 06:53 PM
bythabay's Avatar
I believe I will be doing the same, except I will remove the calipers. I'm installing stoptech SS lines. Doing the calipers in G2 Gold
Old Dec 23, 2008 | 06:58 PM
bythabay's Avatar
Actually I am installing some drilled and slotted e-coated rotors with new pads as well. I'll post pics when it's done.
Old Dec 23, 2008 | 07:07 PM
RickyGill's Avatar
those look good. i gotta try this
Old Dec 25, 2008 | 04:36 PM
kodg man's Avatar
i painted the the round rotor piece that attaches to the wheels black & my rotors silver w/black infinity logos (were the lug nut screws attach) since they were already exposed! with my Piaa wheels style d that area is really visible & the fresh black paint makes the wheel look really clean.
KODG MAN
Old Dec 25, 2008 | 05:24 PM
IrockAG35's Avatar
Ohio G Club moderator
Originally Posted by Gilley
The car looks good, but find some black paint and paint them black. The OEM non-Brembo calipers are nothing to show off. The Hyndai Rio driving down the road next to you has the same basic brakes as the non-Brembo OEM calipers.
+1..i aggree i painted mine GM to match the wheels...clean them up..dont show em off
Old Dec 25, 2008 | 05:38 PM
chenG35's Avatar
Actually this bro had a set of powdercoated red brembos before, he just never installed them and ended up selling them here.
Plus I don't think those VS-XX will even clear the brembos.. he'll prolly need spacers but then the wheels might stick out too much.
Btw nice painting job man
The 05+ brakes are a little larger than the 03-04's but still not as large as the Brembos.
'03 and '04 Non-Brembo Coupes
Front: 11.65-inch x 0.94-inch power-assisted vented disc - 1 piston
Rear: 11.5-inch x 0.63-inch power-assisted vented disc - 1 piston
05+ Sedan and Coupe, '06 Sedan X
Front: 12.6-inch X 1.1-inch power-assisted vented disc - 2 pistons
Rear: 12.1-inch X .63-inch power-assisted vented disc - 1 piston
'03 and '04 Coupe Brembos
Brembo brakes
Front: 12.76-inch x 1.18-inch power-assisted - 4 pistons
Rear: 12.68-inch x 0.87-inch power-assisted - 2 pistons
Old Dec 25, 2008 | 08:50 PM
citymunky's Avatar
My Non-Brembo's were red, but now there are black.
Old Dec 25, 2008 | 09:03 PM
bythabay's Avatar
My calipers are in the laundry room, drying after their 3rd coat. I actually took these photos and noticed some areas I missed, so I went down and added another coat. Also got my new drilled/slotted rotors and stoptech SS lines on...
Old Dec 25, 2008 | 09:05 PM
bythabay's Avatar
I did the first two coats while the calipers where on hangers, and then I waited for the paint to dry and placed them on the table. Then I added a few more coats on the areas the are primarily visible from the wheel area. I painted the calipers completely - full coverage
Old Dec 26, 2008 | 02:00 PM
kodg man's Avatar
Imo i would,nt paint the entire rotor. Your brake pads are going to wear it away. Just paint the machined part of the rotor black or gm. In my case the piaa hyper black w/silver calipers looks clean & doess,nt jump out at you. I think red draws too much attetion to the small oems.
Kodg man
Old Dec 26, 2008 | 02:10 PM
LightningRod's Avatar
Can't see the pics due to work filter ... but I've used Duplicolor on my last car and it was great. The paint didn't fade / chip for the 2+ years I had it on.
Old Dec 26, 2008 | 03:52 PM
kodg man's Avatar
check out this product for your calipers G2 CALIPER PAINT SYSTEM (MUCH HIGHER HEAT RESISTANCE.) I USED THE DUPLI COLOR ON MY MACHINED PART OF MY ROTOR IT'S LIKE 500 DEGREE RESISTANT FINE FOR THAT PART OF THE ROTOR. BUT THE G2 IS BETTER FOR THE ACTUALL CALIPERS AS THE TEMP. GETS MUCH HIGHER. GT IS AVAILABLE AT TIRE RACK. (LIKE $40 BUCKS SHIPPED)
KODG MAN
Old Dec 26, 2008 | 09:55 PM
jeg32's Avatar
Anyone get the calipers powder coated? If so, I'd be curious as to the results and durability.
Old Dec 28, 2008 | 03:19 AM
  #30
bythabay's Avatar
Originally Posted by kodg man
Imo i wouldn't paint the entire rotor. Your brake pads are going to wear it away. Just paint the machined part of the rotor black or gm. In my case the piaa hyper black w/silver calipers looks clean & doesn't jump out at you. I think red draws too much attention to the small oems.
Kodg man
I got mine pre-coated from r1 concepts.. so far they look and perform amazing. The paint where the pad contacted the rotor got rubbed off completely and the rest of the rotor is still coated - looks great! I'll post some pics after my car is out of the shop.
