raising and lowering
Old Jun 2, 2008 | 12:45 PM
CreativeDesignZ's Avatar
Ok so I bought some greddy type S coil overs from someone over on My350z.com, for a great price. I installed them on saturday, fairly easy job just a tad time consuming, now my question is, how do i raise and lower the coil over? I have tein spanner wrenches, as this kit didnt come with them, and it only fits on the bigger lock ring, the one right below the spring perch. Now there are 2 smaller lock rings, but my spanner keeps slipping off of it. Is there anythign i can do so i can drop the front a little bit more? its abotu 1/4-1/2 inch higher than the rear, and the rears fit perfect
Old Jun 2, 2008 | 01:20 PM
redlude97's Avatar
use a screwdriver and hammer to spin it
Old Jun 2, 2008 | 01:27 PM
which collar do i use to spin it tho? there is a large one right under the spring, with a smaller one locking that one, then at the bottom of the shock where its threaded there is another small collar. Thanks again fro your help, nice DG =]
Old Jun 2, 2008 | 01:32 PM
redlude97's Avatar
The one you want to spin I think is the smaller one that the bottom, if its threaded onto the shock, the other collars are for adjusting the spring preload, but I haven't seen greddy typeS coilovers personally. A picture would be very helpful, then I could point out the exact one to be sure.
Old Jun 2, 2008 | 05:06 PM
it is the way u say it is, 2 collars for spring preload, and one at the bottom of the threaded shock, but when i tighten that it only tightens the collar onto the shock more. i need to be able to turn the shock to lower, or turn something so the threads move
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
