Losing pressure after changing the front pads
Old Jun 3, 2008 | 03:44 AM
TranG35's Avatar
Today I followed the DIY on changing the OEM pads with the HAwk HPS pads,everything went smoothly, and i did bleed the brakes before i put everything back together. When time to test drive the car, I realized that I had to push the brake pedal almost half way in to be able to brake, once it passes the halfway mark then the brakes work perfectly. What could be the cause of the problem?
Old Jun 3, 2008 | 03:47 AM
redlude97's Avatar
sounds like a classic case of air in the lines still. bleed all 4 brakes again and see if it fixes the problem
Old Jun 3, 2008 | 09:04 AM
Gilley's Avatar
It isn't necessary to bleed the brakes when changing pads and/or rotors. You probably introduced air into the lines when you cracked the bleeder screws open.
What method did you use to bleed the brakes?
Old Jun 19, 2008 | 11:20 AM
Crashes's Avatar
I know this is an old topic, but Im pretty sure you should have just pumped up the brakes before you drove the car, so your fine now that its pumped up.
Xfactor
Dec 1, 2019 12:52 PM
ghost_g35
Aug 7, 2015 10:31 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
