How hard are sway bars to install?
Old Apr 21, 2004 | 02:47 PM
TheDudeG4's Avatar
I'm thinking about snagging a set of sways very soon, but how hard is the install? I have ramps but no lift, am I screwed?
'04 Coupe 5AT BS | Premium | NAV | 18" Wheels | Borla Exhaust | 350Z Tube | TechnosECU | JWT Pop Charger | Stillen Grounding Kit | Aluminum Pedals | Clear Corners | 15% Centaur Tint
Old Apr 21, 2004 | 03:26 PM
andyranck's Avatar
Re: How hard are sway bars to install?
I was lazy and took my wheels off, but I doubt you need to. You'll probably need some wd-40 to be able to break any bolts loose. As I remember, I even had to use a wrench and a mallet to get the linkage bolts moving. You'll also need to have some deep metric socket attachments to get some of the bolts off. It took me 90 minutes and I had no clue what I was doing.
Drew
2003 G35 Sedan 6MT / Black / Graphite / Prem / Aero
Old Apr 22, 2004 | 11:56 PM
Canton_G35's Avatar
Not too bad, but you should definatly make sure you have all of the tools needed. especially the torque wrench.
I jacked the car up using the factory jack and put it on jack stands. The front was cake, unbolted it and it dropped right out. With the back, some people drop the exhaust. But I just twisted and wiggled it around the exhaust.
I took a bunch of pics for a DYI but I've just been too busy at work.
2003 G35 Coupe 6MT/Black/Graphite/15% tint/6 wire GroundingGear™
Old Apr 23, 2004 | 01:57 AM
badtz's Avatar
a 18" breaker bar makes things very easy.
Old Apr 23, 2004 | 12:42 PM
lloyd's Avatar
I hate to do this to you, but.... the best explaination I have seen is here
http://www.zchickz.com/evo-sway1.htm
I know, I know this is a chick site but it is very clear, well done, and straightforward. She did a lot of work to post this job right, and it shows.
g35C-White, Colorado GGGGONE
Old Apr 23, 2004 | 11:43 PM
glennp_1999's Avatar
A ramp should be ok. I don't think you can fit an 18" breaker bar underneath the car that's just sitting on a ramp or even a jack stand. I used an impact tool to get the bolts out. Like some other people I did unbolt the exhaust connector to remove the back one. There are about 3 bolts holding it so it was pretty easy. Don't forget to apply the silicon grease that comes with the sways otherwise you will hear squicking after a few days.
Here are some pics....
<font color=blue>04 CB COUPE / WILLOW / PREM PACK</font color=blue>
Old Apr 23, 2004 | 11:44 PM
front....
Old Apr 23, 2004 | 11:47 PM
rear...
Old Apr 24, 2004 | 04:02 PM
badtz's Avatar
I had mine up on jack stands. 18" breaker bar fit but i had to apply pressure slightly off 90 degree angle and in smaller arcs. but it really made things easy.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
wuppiedog
Aug 7, 2015 11:16 AM
