Which coilovers for my price range?
Old Jul 7, 2008 | 02:17 PM
SalvadorRuizJr's Avatar
I guess I've narrowed down my choices to the Tein Type FLEX or the Hypermax III Sports both going around the same price (1600-1800). Any votes as to which one is 'better' (for mostly street driving).
Old Jul 7, 2008 | 05:17 PM
Gsedan35's Avatar
Tein makes two Flex models, the Flex and the Mono flex. I did not mention them because neither meets your needs, not in spring rate (too high) or in valving (too stiff). Likewise, based on your needs you should not consider the III Sport, because of spring rate and valving, your needs are met by the regular III model. Just to say it, I'd pick the III sport over the Flex.
Old Jul 7, 2008 | 06:38 PM
You think the ride quality would be really bad on the streets with the III sports?
EDIT: I only ask, because its only a $120 diff in price from where I'm getting it at. You think the discomfort would be too much to warrant the extra $120 and 'better' handling?
Old Jul 7, 2008 | 06:51 PM
5150DS's Avatar
Originally Posted by Klubbheads
After getting my car corner balanced BC racing coils are just amazing. 15 clicks in a rough canyon road perfect. In a smooth track conditions 20-25 clicks should be perfect. Race tires and set the bitch up to full stiff and start tearing **** up.
If you are looking for the best handling and possibly tracking the car, I would defenitely put the cost of corner waiting into your budget like Klubbheads diid.
Old Jul 8, 2008 | 08:50 PM
OCG35's Avatar
Originally Posted by Gdup35sedan
Best bang for the buck right now are the BC Racing coilovers. They run right around $1k. If you want it to ride similar to stock but have better handling performance then i'd go with Tein CS.
-GP-
this is weird... I was set on getting adjustable shocks and keep Eibach Pros... but then today I started researching BC (which I had not heard of prior)... and like within the last week and specifically couple of days I'm seeing a bunch of talk about them... I'm strongly considering them...
Grant, you mentioned Tein Comfort Sport for stock feel with better performance... I'm looking for reasonable ride quality with much better than avg handling characteristics - I understand the BC can be ordered with desired spring rate (but the rates they list are different than what is typically used)... what rate would fit the needs mentioned above?
TIA
Plur
Interior
May 22, 2019 04:35 PM
Plur
Audio/Video/Electronics
Oct 21, 2015 01:40 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
