Alignment specs for 19'" wheels?
Old Jul 14, 2008 | 05:19 PM
Infinite1's Avatar
20 Year Member
Hi all,
I have a 2004 coupe with 19's and I was looking through the service manuals for a 2005 and up coupe in hopes of finding the wheel alignment specs for the 19" wheel. Unfortunately, all I found was for the 17 and 18" specs. Does anyone know where i can find this? Thanks for the help!
Old Jul 16, 2008 | 11:31 PM
Infinite1's Avatar
20 Year Member
TTT....Does Anybody know? Any recommended specs?
Old Jul 17, 2008 | 11:57 AM
kenchan's Avatar
if you're just trying to get it back to factory specs just take it into
the dealer. they'll know wat to do. the alignment angles do not
really change from wheel to wheel unless they measure by mm or inch.
my recommendation...just take it into your dealer.
Old Jul 17, 2008 | 12:30 PM
Infinite1's Avatar
20 Year Member
Thanks Ken for the response! I was kinda hoping someone would say that. I actually have a lifetime alignment from firestone and provided them the specs for the 18" wheel. But since you say it won't change, that is a relief then. I'm back in spec so i'm good.
If anyone else has differing opinions please do share. Thanks!
Old Jul 17, 2008 | 12:50 PM
kenchan's Avatar
if they use degree units it won't change.
the angles are the same.
Old Jul 17, 2008 | 02:18 PM
RST531's Avatar
you can compare it to mine. I also have 19's on my 04.
Old Jul 17, 2008 | 05:35 PM
kenchan's Avatar
^^ looks good. i like to have a tad more toe-in on the rear.
Old Jul 17, 2008 | 11:55 PM
Infinite1's Avatar
20 Year Member
Awesome RST! Thanks! This will definitely help! Right now I can't do a whole lot with the front camber but soon as I get the arms i'll be good. Thanks again!
Old Jul 28, 2008 | 01:55 PM
diesel86's Avatar
RST-
I'm guessing by your signature that you have camber kits front and rear?
Old Jul 28, 2008 | 05:43 PM
cwylie's Avatar
You have camber kits front and rear?
Old Jul 28, 2008 | 07:40 PM
Infinite1's Avatar
20 Year Member
Judging by his sig I'm going to assume he does. I don't have any in the front and I can't get it back to match his spec. And i'm only dropped on 350z htechs
Old Jul 28, 2008 | 07:43 PM
RST531's Avatar
Yes, i do. dropped about 2 inches. just a small gap between the tire and fenders, maybe 1/4 gap.
wuppiedog
Aug 7, 2015 11:16 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 18, 2015 12:33 PM
