endlink options ( I found these endlinks)
Old Aug 18, 2008 | 06:31 PM
05GRide's Avatar
Originally Posted by DaveB
Millionare dollar question though: Do they make any noise what so ever?
Wow easiest million dollars I've ever won!! Not a peep from them! As long as you set them right (neutralize then 1/4 turn to tighten) you won't hear them at all....
Old Aug 18, 2008 | 06:42 PM
GF-4D-G35's Avatar
Too bad you have to split it with me for my quasi answer. I will give your answer more weight and split the 1 large 40/60 with you.
Old Aug 19, 2008 | 04:59 PM
GeeCoupe's Avatar
I went ahead and ordered the OEM revised, got them for a great price...
Old Sep 5, 2008 | 10:14 PM
GeeCoupe's Avatar
I installed the oem revised along with all the wheel bearing( diff noise problem) I STILL I have a clunky noise!!! And the compression rod noise in the front...
Old Sep 6, 2008 | 12:38 AM
GF-4D-G35's Avatar
I don't know what to tell you. I have had similar problems and it is frustrating. I just ordered Tokico Dspec shocks, hopefully that will somehow fix my problem.
Old Sep 6, 2008 | 03:27 AM
GeeCoupe's Avatar
Yeah I have the D-spec as well, at least the compression rod sound is identifiable but the clunking needs to go! I hear it in the rear/middle
Old Sep 6, 2008 | 12:13 PM
GF-4D-G35's Avatar
Same here, I just can't figure out what it is.
Old Sep 13, 2008 | 10:10 PM
GeeCoupe's Avatar
Can anyone help? What are the other things that might be cluncking?
Old Oct 15, 2008 | 05:14 AM
GeeCoupe's Avatar
Bump...... help me out
Old Oct 15, 2008 | 05:15 AM
GeeCoupe's Avatar
Bump... help me out
Old Oct 15, 2008 | 10:35 AM
GF-4D-G35's Avatar
Do you have aftermarket sway bars? If yes and they are Hotchkis you might need to re-grease.
Old Oct 15, 2008 | 11:23 AM
CLyons0203's Avatar
I think we should look into 350Z end links or maybe M35/45 endlinks. They might be longer and stronger
Old Nov 2, 2008 | 03:55 PM
GeeCoupe's Avatar
I JUST changed the end links to the revised, I have stillen sway bars, at the same time I bought new bushings and re lubed them, the sound is bad over bumps, quite embarrassing, sounds like something's loose.
Old Nov 13, 2008 | 07:30 PM
OCG35's Avatar
I am upgrading end links - debated between SPL and Powergrid and decided on Powergrid - they both seem quality and both get good reviews, but I like the design of Powergrid better...
So now for a search to buy - everywhere I look Z-1 is the primary (only) source... it’s almost as if they/he has exclusive rights... but I came across this http://www.ztune.ca/store.aspx?model...00E495&group=8
$211.1r for front and rear!!! I'm concerned that there is no photo though... I would be pissed if it was bogus.
Has anyone bought from them before?
Old Nov 14, 2008 | 01:46 PM
  #30
OCG35's Avatar
I called yesterday to order these - they didn’t have them in stock but were ordering and said they would call with ETA...
Phucking bastards just call me to let me know the $211.16 price they had listed YESTERDAY was wrong - now the price is $296+ (with shipping its no cheaper than Z-1).
Bait & Switch m-er f-ers!!! F those guys
