endlink options ( I found these endlinks)
Old Nov 14, 2008 | 02:54 PM
  #31
OH6 G35's Avatar
Side-by-Side-by-Side...you decide!
SPL, Stock and PowerGrid
Old Nov 21, 2008 | 05:27 PM
  #32
CreativeDesignZ's Avatar
i have powergrids and have clunking, but i dont think its related to the endlink issue. i originally replaced them oems with powergrids because of clunking. i thought my oem endlinks were toast. apparently not.
edit: the endlinks in the pic above on the right look like they can be made from home depot parts, spend the extra cash on the power grids. u can call them up and ask to speak with Chip, he will take care of you
Old Nov 21, 2008 | 06:25 PM
  #33
OCG35's Avatar
the ones on the right are Powergrid
BTW – they can be made using the correct size parts (from just about anywhere) – I was going to make a set using parts from Baker: http://www.bakerprecision.com/rodspl.htm
Old Nov 21, 2008 | 06:42 PM
  #34
errr shiett i meant left lol, damn it ive been getting my lefts and rights confused since i was 3. any fix for that too haha
Old Nov 21, 2008 | 07:55 PM
  #35
OCG35's Avatar
dyslexia ftw (or l?)...
SPL and Powergrid can be made similarly with the right parts... Baker Precision has what is needed - you just need the correct dimensions.
If someone wanted to take the time to figure out the right configuration it wouldn’t be hard (or expensive) to make a set comparable to SPL and Powergrid.
Old Nov 21, 2008 | 08:08 PM
  #36
yea it seems easy, i mean powergrid and spl did the work that were too lazy to do. now if i can just get rid of this damn clunking ill be good to go
Old Dec 11, 2008 | 06:46 PM
  #37
Jeff92se's Avatar
Red Card Crew
Anyone try the Whiteline endlinks?
http://www.jscspeed.com/350z/suspens..._350zlinks.htm
They have the dust boots to protect the joints. Not show above but here
Old Dec 11, 2008 | 06:55 PM
  #38
Klubbheads's Avatar
whiteline makes great products and if I was to get aftermarket, this would be my top choice. If I had known about these, i would have bought them instead of my SPLs that i used to have..
Old Dec 11, 2008 | 07:52 PM
  #39
CLyons0203's Avatar
I would like to see what M35/45 and FX35/45 end links look like.
Old Dec 12, 2008 | 12:07 PM
  #40
those whitelines look NICEEEEEE
Old Dec 12, 2008 | 07:52 PM
  #41
xx7sephiroth7xx's Avatar
G
wow, those whitelines are super nice.
i might just get a set...
Old Dec 12, 2008 | 09:12 PM
  #42
OCG35's Avatar
I recently researched end links extensively… I read about Whiteline and don’t recollect specifics but do recall less than stellar reviews… obviously Powergrid and SPL get a lot of good comments – problem is Powergrid isn’t readily available (very limited vendors carry them, seems like Z-1 has exclusive rights?)… I waiting for a couple things to shake out before I purchase, but it won’t likely be Whiteline.
I think if you search you’ll find the same… if not, I’d be happy to see something I missed in my research.
Old Dec 13, 2008 | 12:27 AM
  #43
G
^ I'll certainly take a look-see.
Thanks!
Old Dec 13, 2008 | 03:56 AM
  #44
OCG35's Avatar
Thanks!
I'd be happy to see your take after further research - please be sure to post
Old Dec 20, 2008 | 03:55 PM
  #45
SDGenius's Avatar
okay... price wise, this is what i found:
-Powergrid Swaybar End Links, Front & Rear($303.94)>>> http://www.ztune.ca/product.aspx?pro...e-0003ff00e495
-SPL Pro Sway Bar End Links, Front($148)>>> http://www.ztune.ca/product.aspx?pro...a-0003ff00e495
-SPL Pro Sway Bar End Links, Rear($148)>>> http://www.ztune.ca/product.aspx?pro...e-0003ff00e495
Total($296)
-Whiteline Front & Rear Endlinks($153 + $129 = $282)>>> http://www.jscspeed.com/350z/suspens..._350zlinks.htm
and then there are these i found...
-CZP Adjustable Front Stabilizer Links($125)>>> http://www.conceptzperformance.com/C...570.181.204.83
-CZP Adjustable Rear Stabilizer Links($125)>>> http://www.conceptzperformance.com/C...570.181.204.83
Total($250)
