Brakes worn @ 95% (Front) and 40% (Rear), should I replace them all? Quote a rip-off?
Old Aug 19, 2008 | 10:58 AM
SkyGliner's Avatar
Originally Posted by trey.hutcheson
Where are you located OP? If you don't track or autocross the car, I recommend sticking with the stock pads. They have great initial bite, and can be had cheaply(less than $100 for all four). Also, they don't require high temps to work.
More aggressive pads will require more heat in them before they become effective. It's usually not a big deal, but in the winter(depending on location) it can be inconvenient for the first few miles.
I am in Phoennix, AZ, so I guess temp is not a problem? I will just leave it under the sun for a hour then it will be burning hot!!! (110 degrees)?
Old Aug 19, 2008 | 11:04 AM
SkyGliner's Avatar
Alright..you guys won.."Changing brake pads with bf" is officially on my calender...
One Q:
I am on a business trip so I can't check if my rotors need to be changed (rockd said @ 61,000 miles, my rotors shouldn't have to be replaced). So let's say I change my brake pads this weekend and then find out that I need to replace the rotors the week after, does it hurt if I continue to use the recently replaced brake pads on the new rotors?
I want the "Big Brake Kit" but they are so expensive!!!
332x32 $1,975.00
355x32 $2,452.00
355x35 $2,543.00
Old Aug 20, 2008 | 10:12 PM
PTownG's Avatar
if you want to keep the rotors at least get them resurfaced. New pads will break in much better on a resurfaced rotor and if the need to be replaced the people resurfacing them will let you know
Old Aug 26, 2008 | 12:20 PM
SkyGliner's Avatar
Updates: I just ordered drilled and slotted rotors and HPS Brakes (all four of them) from OC Autosports. (The total was $398..I thought it's quite reasonable)...I spread this news on another post in the forum....
Now I am wondering if should get the SS lines also as another member mentioned it..
Please look here....https://g35driver.com/forums/brakes-...-hps-pads.html
Old Aug 26, 2008 | 12:34 PM
trey.hutcheson's Avatar
If you're not tracking the car, or driving very aggressively on mountain runs and the like, then I don't think you need SS lines.
SS lines are mostly used to prevent/minimize brake fade; basically they don't expand like the stock rubber lines when the brake fluid achieves high temps.
I'm still on my stock brakes(rotors, pads, lines), front and rear, after 3 years and 65k miles. I've had over 300 passes at the drag strip(decelerating from 100mph), ~150 burnouts(riding the rear brakes), several autocrosses, and several mountain runs. I've never seen a bit of brake fade, but I've never tracked my car.
My point in that little anecdote is that SS lines simply aren't needed if you're not murdering your brakes. On the other hand, I've wanted to attend a local track day, but did not because I was still on the stock pads/rotors/lines. So if you have any intention on tracking the car, then go with the SS lines.
Old Sep 2, 2008 | 04:24 PM
SkyGliner's Avatar
Thank you so much Trey...I took your advise and ended up not getting the SS lines..they cost almost $100...I will have the money better spend on the new tires, I think..
Old Sep 2, 2008 | 04:31 PM
SkyGliner's Avatar
Updates: Haven't got my rotors and pads installed yet..because OC A' send me the pads for sedan instead of coupe...(where's the crying smiley..)
Called OC and they said they will contact the manufactuer and have the right ones resent to me....we will see...
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
