Another brake lines question. Need help with the instal plz
Old Aug 21, 2008 | 09:56 AM
pikush's Avatar
Hey before I get smashed, I did search and couldn't find anything that would help me. So I did my brakes last nite, pads, rotors, lines. But there was no instruction with the lines so we just put them on how we thought they made sense. But when you turn the wheel all the way the line touches the rotor which we all know shouldn't happen and is unacceptable. So pls can someone show me how they go. Here's how I have 'em on right now. Pls I'm desperate, someone help.
Old Aug 21, 2008 | 05:44 PM
pikush's Avatar
come on guys, i really need some input here...
Old Aug 21, 2008 | 05:52 PM
Jeff92se's Avatar
Red Card Crew
That seems basicly correct. Maybe that tab has the line pointing down towards the rotor too much
Old Aug 21, 2008 | 06:53 PM
pikush's Avatar
thanks a lot man, but do your lines rub against the rotors? your lines seem to be shorter than mine or is it just an angle of the pic?
Old Aug 21, 2008 | 08:46 PM
Jeff92se's Avatar
Red Card Crew
Not my pic. But yeah, your lines seem longer
Old Aug 21, 2008 | 09:44 PM
twin001's Avatar
Can you take in some of the slack on the left side of the pic? In other words, pull on the right side of the line toward the rear of the car.
Brakes look great by the way, I like the rotors.
Old Aug 23, 2008 | 12:56 PM
pikush's Avatar
Hey first of all thanks for the advice and the comment on my brakes. But now, it doesn't help to pull the extra line toward the back because then there's so much left over that when it "folds" on the turn, it touches the rotor anyway. And shouldn't the line be moving through the bracket back and forth depending on how the wheels are positioned?
Old Aug 26, 2008 | 09:17 AM
pikush's Avatar
Come on anybody else? I really need help.
Old Aug 26, 2008 | 01:28 PM
Scrooge's Avatar
Yeah you should thanks about buy a short brake line hose. First test with string to see what length you might need.
Old Aug 26, 2008 | 01:36 PM
Jeff92se's Avatar
Red Card Crew
You could try turning the mounting tab upside down so the line is higher?
Old Aug 26, 2008 | 02:01 PM
Gilley's Avatar
That's the way I have always mounted straight lines.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
