Front OEM Brembo cliper is making clicking noise
Old Aug 22, 2008 | 11:37 AM
badassflip's Avatar
Question Front OEM Brembo caliper is making clicking noise
So my front passenger side brembo is making the clicking noise. I went out to check on it, i saw a little piece of metal behind the caliper was touching against the rotor. I took the car to a shop, a mechanic told me that i need to replace both the break pads and the rotors.
I understand that i will need new break pads, but, not that i don't trust the guy, how can you tell if you need new rotors by looking at them?
Old Aug 22, 2008 | 02:20 PM
badassflip's Avatar
no one knows???
Old Sep 15, 2008 | 04:46 PM
G-MENTED's Avatar
maybe that explains the same clicking im getting in the front as well.
Old Sep 15, 2008 | 05:10 PM
mIKE's Avatar
Measure the thickness of the rotor, and check to see if they're within factory spec.
You'll want to do this with calipers, as the spec's are very very specific.
rezendvous420
May 31, 2020 01:26 PM
cyrus32
Jul 18, 2015 06:22 PM
mushu
Jul 15, 2015 03:55 PM
