View Poll Results: Which Spring Set do you recommend for me?
G35 H-Techs
25.93%
350Z H-Techs
11
40.74%
S-Techs
37.04%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Flat Out - What drop can I do w/ no mod other than Springs?
Old Aug 29, 2008 | 09:36 AM
WhiteonWheat's Avatar
Question Flat Out - What drop can I do w/ no mod other than Springs?
I hope my Title question makes sense?
What I'm looking for:
A 1" - 1.5" drop that requires no other mod's (camber kit, whatever).
Did research prior to asking this question and I hear the G35 TEIN H-Tech's might be my ONLY choice.
I read that the 350Z TEIN H-Tech's are great on the G35, but tend to lower the front more than the rear - requiring a mod for the REAR, and then hearing that I'll need to FLIP my tires to avoid un-even wear.
So basically, I want to know if it's even POSSIBLE to drop this car any lower than STOCK and not have to mess with anything other than switching out the SPRINGS?
Hopefully that's an easy "straight-forward" query for you quys to help me with?
Thanks as ALWAYS Guys!
-WoW
Old Aug 29, 2008 | 10:14 AM
jserman's Avatar
when you start lowering your car your going to start having camber issues... depending on how low you go...
so either deal with the camber or get camber kits
Old Aug 29, 2008 | 10:46 AM
Texasscout's Avatar
None of the above. You must keep it at 1" or less or you will have issues.
Old Aug 29, 2008 | 01:37 PM
jigahus's Avatar
350z htechs
Old Aug 30, 2008 | 11:11 AM
^ Ok, cool - so what will drop me 1" exactly the (below mentioned?)
350z htechs
Thanks Guys!
-WoW
Old Aug 30, 2008 | 11:24 AM
Texasscout's Avatar
I thought 350Z Htechs would give you 1.5" or more?
Stock 350Z springs are cheap and avallable, they will give you 0.9" to 1"
Old Aug 30, 2008 | 12:22 PM
Manual G's Avatar
So 1" or less wont affect camber at all?
Old Aug 30, 2008 | 12:46 PM
gary c's Avatar
In reality there is no way to drop your G without having an issue. The Tein
350Z H-Techs will give you the least amount of drop but then you still have
the choice of getting Toe bolts/adjusters or buying rear tires every year
or two. In the long run it's cheaper to buy the springs and adjusters for the
rear and have it aligned after install....
Gary
Old Aug 30, 2008 | 12:56 PM
r0csfinest's Avatar
350z h-techs but just save up so you can get the drop you REALLY want
Old Aug 30, 2008 | 01:51 PM
Texasscout's Avatar
I put the 350Z springs in my sedan, I got a 1" +/- drop. Once I had the toe in adjusted, I have had no tire wear issues.
Old Aug 30, 2008 | 02:01 PM
Da-G-SpoT's Avatar
Arent Sedans and coupes different as far as springs? I thought that 350z springs will drop a sedan 1" or so but not a coupe. I am confused now.
Old Aug 30, 2008 | 05:06 PM
redlude97's Avatar
They are different, all the suspensions are the same, but the spring length and the corresponding camber/toe ranges are different. By using 350z OEM springs, you are essentially just going to the 350z OEM alignment settings. That is why Texasscout doesn't notice wear issues on his sedan. 350z h-techs on a sedan will drop it 1.7-1.8", which will then cause issues on the sedan.
Old Aug 31, 2008 | 10:10 AM
Q45tech's Avatar
Since springs major role is just to support the body, they have little effect on measurable handling. They do affect the feel to the driver and can cause problems if the fore/aft roll stiffness ratio is thrown out of balance.
Lowering [the center of gravity] can reduce the transfered cornering forces on tires by 1-2%.............whether 1-2% is worth all the problems and extra mainteance cost depends.
Lowering with a heavier tire and wheel is at best a wash if you are lucky.
Old Aug 31, 2008 | 04:34 PM
Texasscout's Avatar
Checked the front tires yesterday and I do have some abnormal wear on the insides of the front tires. Camber arms here we come....
Old Aug 31, 2008 | 09:36 PM
redlude97's Avatar
If its not a whole lot, then just have the tires flipped if the are symmetrical. Usually you have to go through 3-4 sets of tires before the camber arms pay for themselves.
