Clunking sound from front suspension
Old Sep 1, 2008 | 12:46 AM
5150DS's Avatar
When I turn right or left or go over speed bumps I hear a clunking sound coming from my suspension. Does anyone else have this or does anyone know what it might be. It just started the other day and of course I am 3k miles out of warranty.
Old Sep 1, 2008 | 12:59 AM
SDGeneralCounsel's Avatar
check your suspension bolts. Could be something stupid and simple as a bolt missing.
Old Sep 1, 2008 | 02:44 AM
EL-EE-ES's Avatar
check to make sure your lug nuts are tight. when i first lowered my car i took it for a spin and everything seemed fine. after 2 days i started to here clunks on slow bumps (like driveways) from the pass. front and it slowly started to get worst. so after about a week i took the wheel off to see what the problem is. i notced the the lugnut spun off pretty easy, still snug but not tight. everything else checked to be torqued on right. so i put the wheel and lugnuts back on tight and i havent herd a clunk.
Old Sep 1, 2008 | 07:52 PM
5150DS's Avatar
Well, I took off my wheels and checked; everything appeared fine. I checked my sway bars and they needed to be re torqued. After I put everything back together I took it out for a test and the noise is gone. Could have been to sways or the lug nuts, either way the noise is gone. Thanks for the help.
Old Sep 1, 2008 | 08:41 PM
EL-EE-ES's Avatar
good to hear you found the problem. i was pissed off that i spent one hour checking each bolt and it ended up being my lugs..ha
tiguy99
Mar 1, 2016 11:42 AM
Fireman07603
Aug 9, 2015 06:00 PM
kinetek
Aug 3, 2015 04:25 PM
jimNC
Jul 25, 2015 05:47 AM
cyrus32
Jul 18, 2015 06:22 PM
