Springs really need camberkit?
Old Sep 1, 2008 | 05:27 PM
Ching1206's Avatar
im planning to get some springs....
I know anything with 1inch+ drop needs camber kit...
Im not sure whts camber kit....
But is it really necessary to get camber kit if i drop my car more than 1inch?
Wht if i lower it more than 1inch n not get camber kit???
Wht will happen if i dont get it???
Old Sep 1, 2008 | 05:34 PM
graph35's Avatar
its only necessary if you like your tires...
Beebo's Avatar
your tires will wear out ALOT faster... a camber kit is alot cheaper then new tires
Ching1206's Avatar
OOH i see
then if spring+camberkit
then might as well get coils?
Old Sep 1, 2008 | 05:59 PM
Beebo's Avatar
you will need a camber kit with coilovers as well unless you plan on keeping it at the stock hight
Old Sep 1, 2008 | 06:37 PM
EL-EE-ES's Avatar
+1...any type of lowering will require camber kits if you want to slow tire wear down
Old Sep 2, 2008 | 11:30 AM
Q45tech's Avatar
Unfortunately, while a camber kit can fix the static camber, it does nothing to correct the change in camber curve caused by body lowering which CHANGES the ANGLE of the attachment points on the frame. Same with Caster curve!
When you lower you create toe curve [steering] changes which also require changing angles on tie rod ends to return them to parallel with road.
Simple lowering creates massive errors in suspension design that cannot be fixed cheaply or easily..................95% of lowered cars never are TOTALLY fixed to comply with oem designs.
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Chauzilla
Sep 27, 2015 04:34 PM
