URGENT - Suspension noise, from rear driver coilover
Old Sep 16, 2008 | 12:41 AM
g7x5's Avatar
Exclamation URGENT - Suspension noise, from rear driver coilover
for reference - coilover are mono flex about 1-1.5 finger space low, have hotchkis sways on medium, all spc camber parts, and all gt spec bars
My rear driver coilovers are making a metal clanking noise. jacked it up this evening and i think it's the lower collar, not sure if there is a way to tighten it back up. The center rod part is kinda loose also is this a defect or just something i can fix. It's annoying as hell some help please, i don't want this to fail specially since i have to drive it more with making this noise.
from a picture i found on the web,
it's the lower pillow lower collar that's somewhat loose
Old Sep 16, 2008 | 05:29 PM
kenchan's Avatar
if it's really loose, why not just add a spacer/collar in there to rid the play?
Old Sep 16, 2008 | 09:33 PM
g7x5's Avatar
well it's not making any noise anymore and i think it's settled now, i guess i'm so paranoid something is gonna go wrong.
Old Sep 17, 2008 | 02:48 PM
kenchan's Avatar
yah, that lower collar probably cracked and fell off somewhere.
Old Feb 26, 2009 | 10:53 PM
Matthew121's Avatar
hey sorry to bump a really old thread, but I am having thi issue with my greddy type s coilovers, its a clunking sound in what I think is the right rear coilover, Ive had the coils on for 3 days now, and it jus started doing it tonight, what collar are you guys talking about? thanks for your help!
Old Nov 27, 2009 | 07:09 PM
g7x5's Avatar
ok super late update, but anyways it was fine for a while till it started to get cold again, it used to make little noise across only large bumps, but as the temp started to drop it got worse this year. Finally had time to take them out this week, and found out it was the bolt holding the collar down, if you have tein's check the bolt highlighted below to make sure it's tight, and no more noise.
again this is what was making the noise in my case, this may not be the case with yours
rezendvous420
May 31, 2020 01:26 PM
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
cyrus32
Jul 18, 2015 06:22 PM
