Stock range of camber adjustment(05 G35 coupe STS)
Old Nov 27, 2009 | 09:02 PM
abwrestling33's Avatar
Does anyone know the stock range of camber adjustment in a stock 2005 G35 coupe with the sport tuned suspension package? I've had bad tire wear on the inside of the front tires since I bought it new. I had the alignment adjusted as much as the stock suspension allows but its still an issue. I noticed the Ichiba camber kits allow for + or - 3 degrees camber adjustment but I'm not sure if that is a major improvement from stock adjustment range. Is there another way to adjust my stock camber further than the stock allows or do I need to shell out the $280 for a set. Money is a bit tight so if there is another way, let me know. Thanks for the help!
Old Nov 27, 2009 | 09:12 PM
Just to give the stats, with the camber adjustment maxed out on the fronts, the camber on the left is -1.3 degrees and the right is -1.5 degrees
Old Nov 28, 2009 | 06:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Unfortunately there is very little camber adjustment available stock. If you want more flexibility, you'll have to get a kit.
Make sure your toe is in spec, it causes more wear than the camber.
Old Nov 28, 2009 | 02:02 PM
toe is -0.07 degrees on the left and 0.10 degrees on the right. I don't know if this is in spec but they seem to be extremely small and considering how they are both off in the same direction(towards the drivers side of the car), the difference between them is only 0.03 degrees. Therefore, I am assuming its the camber thats the biggest problem. I don't know too much about this so let me know if my analysis is wrong.
jimNC
Jul 25, 2015 05:47 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
Carlos_G358696
Jul 18, 2015 03:22 PM
nascarbuff17
Jul 16, 2015 10:23 AM
