Need advice on installing rear rotors
Old Sep 22, 2008 | 04:09 PM
sportsnbikes's Avatar
Brakes Need advice on installing rear rotors
Hi--I am trying to install rotors on the rear of my 04 G35X. The problem is that I can remove the caliper bolts and remove the caliper. But there are 2 more bolts that need to be loosened to remove the rotor--I can't seem to loosen them--does anyone have any advice on how I may be able to get them loose. Keep in mind that I am a tall, skinny guy with not much muscles and no spinach!!!
Old Sep 22, 2008 | 04:26 PM
mIKE's Avatar
use a breaker bar. If you don't have one, get a piece of pipe or something that can "extend" the length of your wrench or whatever tool you're using.
Old Sep 22, 2008 | 10:44 PM
Mike--Thank you. I have a breaker bar--the bolts don't quite fit the 19mm socket. There is a little play but the 18mm is too small. I will try the breaker bar--there's just not much room in there. I didn't know if I even needed to remove them but you sound like you know what I'm talking about!!
Old Sep 22, 2008 | 10:51 PM
mIKE's Avatar
Hmm... the bolts SHOULD be 19mm.
double length = double the torque. Just be careful to keep your socket/wrench ON the bolt (may want someone to steady it for you).
You don't want to accidently break or strip something that important.
Old Sep 23, 2008 | 12:37 AM
G-MENTED's Avatar
takin out the rear rotors is a PITA. definitely use a breaker bar and wd40 or something.
Old Sep 23, 2008 | 04:17 PM
spinn's Avatar
might want to be sure you do this while the car is not on jack stands.
Old Sep 23, 2008 | 04:21 PM
iamericgee's Avatar
get some pb blaster it is a penetrating catalyst ! it is a nut and bolt remover ! spray it on let it sit for like and hour and it should come right off!
Old Sep 23, 2008 | 05:03 PM
What would you receommend I have it on--someone told me the other day not to have it on the jack as well--I don't know what else I would use.
Old Sep 23, 2008 | 05:34 PM
mIKE's Avatar
If you have it on jacks, you'll need to make sure the car is VERY secure.
Jack only as much as absolutely needed, and have wheel chocks on all 3 other tires. Strap the car into place if you can.... you wanna make sure the car DOES NOT MOVE when you're putting a load on that bolt.
You'll be very unhappy if the car just drops to the floor.
Old Sep 23, 2008 | 11:11 PM
Thumbs up
WOOOOO HOOOOOOOO!!!!! FINALLY!!!! Once the bolt was off--it almost was finished in an instant!! But since I am a dummy, I took off the stupid spindle bold or whatever it's called--but, for a first timer whose never done a brake job ever--that was pretty dang simple. Thank you to everyone for their help!!
Next up--Driver side rear tomorrow night!
Old Sep 25, 2008 | 06:25 PM
1YoungOwner's Avatar
Brake Job
What is it like replacing and installing the front rotors\pads for a first time brake job?
Old Sep 25, 2008 | 11:55 PM
I didn't do the front but my dad said getting the bolts off are easier because you can turn the wheels.
Old Oct 28, 2008 | 05:12 PM
mr2willwin's Avatar
I went to do my rears, and got the caliper completely off, but the rotor wont budge, I sprayed it with PB, but it wont come off, am I missing something? its a 05x, I did both fronts with pads and rotors in about an hour, but the rear wouldn't budge....
Old Oct 28, 2008 | 06:44 PM
G35Papa's Avatar
^Make sure the e-brake is disengaged.
What I did to get mine off was spray the hub with PB Blaster then take a long screw driver and put it inside the veins of the rotor...then wiggle back and forth. Do this on multiple sides of the rotor...it will eventually come loose. You can also try using a rubber mallet to hit the rotor from behind.
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
