will this get in the way, when i lower the car?
Old Oct 6, 2008 | 03:23 AM
WV2G35's Avatar
sorry im not technical when it comes to describing "this"."This" thing sits like 2 inches above the tire. Will this be in the way when i lower my G?
Thanks in advance
Old Oct 6, 2008 | 03:42 AM
dofu's Avatar
20 Year Member
Your pic sucks, but I'm going to go ahead and say it won't be a problem at all.
Keep in mind that your wheel has lots of movement already. Your suspension is meant to move horizontally. If you have enough weight in your car, the wheels will tuck as it is. If that bolt is a problem, then you'd be screwed already.
And plus, if it's a problem at all, you'd see plenty of threads about it already.
Old Oct 6, 2008 | 04:00 AM
WV2G35's Avatar
sorry about the pic, zoomed in too much.Thanks.
Old Oct 6, 2008 | 06:12 AM
EL-EE-ES's Avatar
if thats on the upper arm on the front, no it will not since it moves with the suspension
Old Oct 6, 2008 | 02:08 PM
kenchan's Avatar
lol... yah, +1.
that will move parallel with the tires so it will not get into the
way.
Old Oct 7, 2008 | 07:19 PM
visibiliti's Avatar
if you ever get the chance to look into your wheel well at your suspension components with your wheel off, you will realize how funny of a question this is
and, no, it won't be a problem... like the above guy said, it moves with the suspension !!
Old Oct 7, 2008 | 07:41 PM
ShanesG's Avatar
^+1 that piece moves as your wheels move, it's connected to your hub, so the way your tire sits, it will never get closer than it already is!
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
itschuckster
Jul 25, 2015 08:07 AM
Kal Hamm
Jul 24, 2015 08:55 AM
Karnicle
Jul 23, 2015 05:08 AM
