Can anyone give me some good advice?
Old Oct 12, 2008 | 10:50 PM
xXHotelCrazyXx's Avatar
I need to make a decision by tommorow and i havent had any luck asking the same question in the wheel section. Anyways i bought some really nice wheels ( the offsets arnt the best but they look great) and i want to get some spacers. Here are the specs of the wheels
19x8.5 40mm front
19x9.5 35mm rear
would a 25mm spacer go best in the front and a 20mm spacer in the rear or do i have them mixed up? If i do go with a 25mm in the front and a 20mm in the rear would i have to roll my fenders? Thanks so much
Old Oct 12, 2008 | 10:54 PM
typo "advice"
Old Oct 12, 2008 | 11:00 PM
Calvin's Avatar
Overglorified Altima
The biggest spacers that I've seen are 25mm. If you insist on keeping these wheels, then throw 25's on all four corners. It won't be flush, but it's the closest you'll get. You'll want to roll/cut the rear fenders (fronts come rolled from the factory).
IMO, ditch these wheels for some with better fitment.
Old Oct 12, 2008 | 11:08 PM
so i will only have to roll the rear fenders and i should throw 25 on all 4?
Thanks so much calvin, you da man
Old Oct 12, 2008 | 11:13 PM
Calvin's Avatar
Assuming your drop/camber/tires requires it, then yeh. I'd roll the rears to be safe.
Old Oct 12, 2008 | 11:18 PM
ShanesG's Avatar
25's on all 4!
Then they'll be 15 front and 10 rear for offsets
But yeah they won be flush
I'm running a 9.5 rear with -1 offset and it's still not flush
Old Oct 12, 2008 | 11:20 PM
im dropped on tein s-techs, so what do you think??
Old Oct 12, 2008 | 11:21 PM
Originally Posted by ShanesG
25's on all 4!
Well if they arnt totally flush thats fine, but as long as i can get it pretty close!!! Thanks shane!
Old Oct 12, 2008 | 11:37 PM
Also with 25mm spacers, will i have to mody my stock lug studs? Will they stick out too far through the spacer that they will actually be pressed up against the wheel?
Im just worried that the wheel wont be able to sit flush against the spacer because of the factory studs will be too long.
Old Oct 12, 2008 | 11:47 PM
Calvin's Avatar
25mm spacers will either come with built in studs or separate extended studs. Extended studs are recommended for any spacers beyond 3mm.
Old Oct 13, 2008 | 12:02 AM
The ones im looking at has holes for your factory lugs to go through and it has new studs pressed in. Now when i slide the 25mm spacer over the factory studs, are the factory studs going to stick out to far from the spacer and the wheel, rather than sitting flush against the spacer, will be sitting against the lugs? Im just worried thats how its going to be and i might have to cut the factory studs down so the wheel will sit flush against the spacer?!?!
Old Oct 13, 2008 | 12:13 AM
Calvin's Avatar
Not all wheels will accept bolt on spacers. If your wheels have room for the stock lugs to go into, then you'll be fine. Just take a look at the back of your wheels and see if there is space.
Old Oct 13, 2008 | 12:21 AM
Andrei's Avatar
I hate camber. Stock camber eats tires with 500 thread.
Old Oct 13, 2008 | 12:24 AM
Skaterbasist's Avatar
Retired SuperMod
Why not just get more aggresive wheels?
IMO, 8.5f/9.5r is a weak setup for a coupe, especially in the offsets you've mentioned in prior threads.
Anyhow, good luck and enjoy!
Old Oct 13, 2008 | 12:30 AM
I really love the wheels i bought, they will look great any how but the just need some more offset, i will try to do a little more research! Thanks to everyone for the great help and opinions!
