Are my camber degrees correct?
Old Oct 27, 2008 | 06:39 PM
elayman's Avatar
I have a 2005 coupe and I just got my alignment done.. At the top of the page it says G35 sedan but the guy assured me it was the same can anyone confirm if these are the right specs? Also he said it is maxed out and cannot be any more positive in the rear? what's up with guys running positive camber and such?
here are some pics of the rear
Old Oct 27, 2008 | 06:40 PM
elayman's Avatar
let me know if you need better pics of the car/wheels from behind
Old Oct 27, 2008 | 06:48 PM
redlude97's Avatar
that seems about right, the rear right toe could be decreased a bit, and I would have them even out the front toe ~0.04, but without camber kits they can't do much more than that
Old Oct 27, 2008 | 06:50 PM
elayman's Avatar
i dont have a front camber kit so the front was not adjusted more than the toe.. are the adjustments bad? is it worth taking back and forcing them to do it and waste an hour of my day?
Old Oct 27, 2008 | 06:55 PM
redlude97's Avatar
technically they got it within specs. Unless you specified exactly what you wanted, and they agreed to set it to those values(which usually costs quite a bit more than a normal alignment, and a good alignment shop) then they did their job.
Old Oct 27, 2008 | 09:05 PM
elayman's Avatar
okay it comes with a 1 yr warranty if it goes out of spec but its fine for me.. just wanted to make sure this was the right values for a coupe
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
