anyone have this camber kit on their G???
Old Nov 7, 2008 | 12:22 AM
ptd23's Avatar
http://www.g35parts.com/9083/osc/pro...c41a8b272b143b
are they worth getting???
Old Nov 7, 2008 | 12:24 AM
Calvin's Avatar
Overglorified Altima
Worth getting? Depends on your goals. If you're trying to correct your negative camber, then no. If you're trying to add additional negative camber for track purposes, then yes.
Old Nov 7, 2008 | 12:27 AM
ptd23's Avatar
i'm just trying to prevent my tires from gettin eaten up when i decide on which tein springs im going to get.
Old Nov 7, 2008 | 12:31 AM
Calvin's Avatar
http://www.cusco.co.jp/en/parts_prod...nsion_arm.html
Increased cornering performance.
By fitting these negative upper arms, the tires contact patch increase under cornering for greater performance.
Old Nov 7, 2008 | 12:34 AM
ptd23's Avatar
thanks man, which lowering springs would look good and ride ok, with my oem 19's
Calvin's Avatar
FYI: They're cheaper here (not that it matters since they are meant for adding negative camber, not correcting it).
http://intensepower.com/necaupa35g35.html
I'd look into SPL arms for correcting your negative camber.
https://g35driver.com/forums/suspens...ways-sale.html
Old Nov 7, 2008 | 12:36 AM
ptd23's Avatar
Originally Posted by Calvin
For the price of those Cusco's, I'd look into the SPL's. These will correct your camber.
yeah i couple people on frenzy told me to look into SPL's, what site can i buy the whole kit from? i searched for it but cant really find a good site to buy from. btw sorry for all these dumb questions lol
Old Nov 7, 2008 | 12:37 AM
Calvin's Avatar
Depends on how much of a drop you're looking for. Conservative - H Techs. Aggressive - DF210.
Calvin's Avatar
You can buy them from our site sponsor...look at the thread I linked you to...
Old Nov 7, 2008 | 12:39 AM
ptd23's Avatar
i just wanted to lower it enough so i dont have that much of a wheel gap.
Old Nov 7, 2008 | 12:41 AM
ptd23's Avatar
which would you suggest? i have no clue
Old Nov 7, 2008 | 12:46 AM
tragedycat's Avatar
I run SPC front and rear camber kit, got me back into spec and haven't had a problem with them yet. I don't do any tracking, just highway cruising and some occasional spirited driving, so I don't need some $1000 350evo arms or anything, so if you are in the same boat as me look into SPC.
Just make sure you get the revised fronts from SPC.
Old Nov 7, 2008 | 12:50 AM
ptd23's Avatar
yeah im in the same boat....lol....where did you get yours from??
Old Nov 7, 2008 | 12:51 AM
Calvin's Avatar
Old Nov 7, 2008 | 12:52 AM
tragedycat's Avatar
THMotorsports, they are a sponsor on here. Just go to the marketplace suspension section. They run a really good deal if you order front and rears at the same time.
