tein s tech. Help!
Old Nov 10, 2008 | 08:40 AM
G_whip's Avatar
tein s tech. Help!
so i just got back form germany the other day and i got to drive my g.......... well i got to tell you that the ride quality went to **** it shakes when i hit the gas at speeds above 60, bumps are like im in a caddi and the damn thing spins out when cornering faster than 40 dose anybody have this problem i know they told me to wait till the springs settle but **** its been 8 months if they aint settled by now theres a problem i do have the ichiba rear camber kit not sure what to do to stop this can someone help me!!!!!!!!!!!
Old Nov 10, 2008 | 08:18 PM
G_whip's Avatar
ttt
Old Nov 10, 2008 | 08:25 PM
G_whip's Avatar
bump
Old Nov 11, 2008 | 03:34 AM
uprockd's Avatar
are these for the g or z? the car shaking can be due to that you havnt got an alignment or you have aftermarket rims i mean my car shakes like that when i pass 80 mph. i guess thats wat happen when you lower your car yes it is bumpy
Old Nov 14, 2008 | 12:20 PM
kenchan's Avatar
tires got flat spots maybe and needs to be broken in.
Old Nov 27, 2008 | 11:13 AM
XBrisk202's Avatar
yeah, i think it's probably your alignment
springs only take a few weeks to settle
Old Nov 27, 2008 | 11:58 AM
EL-EE-ES's Avatar
tires may need to be balanced...has the car been setting for awhile? my car sat in the garage last winter and had the same problem when it came out this last spring? got it balanced and all is good
Old Nov 27, 2008 | 10:35 PM
dmitriylm's Avatar
Your car should never sit on its tires for an eight month duration. Most people put their cars on jacks to relieve pressure on the suspension and tires while a vehicle isn't being driven for long periods of time.
Old Nov 28, 2008 | 07:21 PM
Karma's Avatar
Putting the car on jacks is far worse that leaving the wheels on the ground. With the car on jacks, the ground needs to be perfectly flat or else the body will twist. Also, with the weight of the wheels/tires on the suspension, it strains your shocks/springs by putting load on them opposite to what they were made for. If your that concerned about leaving tires on the ground, put a piece of carpet under them.
Old Dec 2, 2008 | 05:31 PM
1trueG's Avatar
You need an alignment. My car did the same thing after I lowered it. It would slip and slide over every little bump. After the alignment, it rides alot better.
KruZZe
Feb 27, 2023 05:04 PM
nissandrifter32
Dec 22, 2015 04:28 PM
bigmike
Sep 17, 2015 01:58 PM
