G35/350Z share same suspension as 02+ Q45???
Old Nov 13, 2008 | 05:28 AM
executivea4's Avatar
hey fellahs, i was just wondering if any 350Z/G35 experts can chime in on this... i need to get (negative) camber to run some -32mm ET offset rims on my 02+ Q45, my alignment shop said my front/rear camber is non-adjustable, so i was wondering if 350Z front A-arms and 1) rear radius arms; 2) rear lower arms and 3) rear camber arms for my Q but was just wondering they share the same components.
i've tried google.
i've used the search button.
any suspension guru can chime in?
thanks in advance and aloha from hawaii...
here's my front suspension diagram:
Please select a corresponding number from the illustration below to view the details of that part.
1) Knuckle Back 2) Lower cntrl arm Right 3) Bolt Front Back
4) Stay bracket Back 5) Susp crossmember 6) Stopper Stopper Back
7) Bolt Bolt Back 8. Dynamic damper Back
here's my rear suspension diagram:
1) Knuckle Right 2) Bushing #1 Back 3) Bushing #2 Back
4) Bushing #3 Back 5) Bushing #4 Back 6) Dust shield Dust shield Back
7) Upper cntrl arm Right 8. Nut Nut Back 9) Arm joint cover Back
10) Lower cntrl arm Right 11) Bushing Bushing Back 12) Lateral arm Back
13) Bushing Bushing Back 14) Radius rod Back 15) Bushing Bushing Back
16) W/o sport package W/o sport package Right 17) Susp crossmember 18. Stopper Stopper Back
19) Dynamic damper 20) Cross bar
MY INTENDED SOLUTION:
i am planning to order the megan racing:
Nissan 350Z Rear Radius Arms
Model Number : MR-6335
Nissan 350z Adj. Rear Lower Arms
Model Number : MR-6479
Nissan 350Z Rear Camber Arms
Model Number : MR-RCA-N3Z
any G35/350Z guru can chime in?
thanks! mikey
Old Nov 13, 2008 | 05:33 AM
god help us all:
(my car)
Old Nov 13, 2008 | 12:27 PM
sugsss's Avatar
oh chit -32 on a stock body f50 that is crazy, well I'm not to sure what parts are able to crossover I have some aftermarket front upper a-arms we can compare, I live in Waipahu lmk shoots.
are u on vsc? widebodyQ might have some suggestion.
Old May 28, 2012 | 08:06 PM
Dani01c's Avatar
Does anyone know if the front lower arms from a 350z fit on a 2005 G35 sedan?
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
