Ichibia Rear Camber Kit???
Quick question:
I have the rear camber kit for ichibia, and the part number is 72056, my question is, is this a replacement toe belt, or can I use this?
I know the SPC ones come with it...but, do the ichbia ones?
Do you mean "Is there a replacement toe-bolt?" I can't really understand the context of your question...from what I have heard, the Ichiba does not come with a new adjustable toe-bolt, the SPC toe-bolts should work though because the Ichiba (like SPC) is similar to a stock design.
i bought a ichiba rear kit and was still having problems getting back to 0 for the alignment. i was wondering do i have to buy an spc rear toe kit to fix this since ichiba doesnt make toe kits? or what should i do?
it did.. is that all i need? when i bought the ichiba rear kit it came with the 2 arms for the rear and 2 bolts that i thought were needed for the rear arms and not the toe arms but i just used the old stock bolts and kept those on the side. im still a little confused about the whole thing on what else i need
2. You don't want/need to have zero camber. -1 to -1.6 is a good amount for a compromise between handling and tire wear as long as you can set the toe in to somewhere between 0.05 and 0.1
okay he said my camber was still about a -1.7 to -2.0 or so after installing the rear camber arms so by just putting in those 2 toe bolts it should be between -1 to -1.6? i thought i would need 2 more arms for the toe but i guess u just need those bolts is what i comprehend from this. thanks a bunch.
yeah i didn't know those were the toe bolts... just figured those were the bolts for the camber arms and required another kit for the toe but thanks for all the info. saved me some money and time. thanks again!
1. You need to install them on the end of the springbucket. Follow this DIY http://turboneticsownersclub.com/tur...oltinstall.pdf
actually i had a question a bit off topic about the install of the rear ichiba camber kit. Is there any hacking involved in this kit meaning cutting into the piece of metal where the bolts is mounted for the toe i believe or is it a direct replacement from the factory? can someone verify? i cant find it posted
