i need help lowering imma noob
Old Jan 12, 2009 | 06:18 PM
occman's Avatar
i tried searching, but its not working
what exactly do i need to lower my car, and how much should i lower it
my cuz is telling my i cant lower it on just springs then my shocks would get messed up.
is this true?
he says i need to buy coilovers
how much should i lower it also?
Old Jan 12, 2009 | 06:31 PM
Swivel's Avatar
Moderator
Coupe or sedan? How low do you wanna go? If search didn't work, you may be doing it wrong.
Briefly, 350z springs will lower a coupe 0.5", a sedan 1.0" and a sedan X 1.5". Beyond that, you're into the aftermarket, search on "Tein", "coilovers", "Eibach", you should get several bezillion hits.
Old Jan 12, 2009 | 06:34 PM
cremaster's Avatar
you can get aftermarket springs only and it won't affect your shocks too much if you stay w/in an inch (for sedans).
Old Jan 12, 2009 | 06:42 PM
Swivel's Avatar
Moderator
Oh yeah, the shock thing. 05-up Z spring rates are high and will kill your shocks if you are in a non-sport car (03-05 sedan sport shocks are RED, to help you tell) so the best way is to swap shocks and springs at the same time OR run unrevised (03 and 04 generally, but you can tell cuz they have two red and one white dots on them) springs with sedan sport shocks.
Clear as mud? Search lots, read lots, you'll get it.
Old Jan 12, 2009 | 07:57 PM
occman's Avatar
sorry its a 03 coupe
if i go aftermarket springs, and no coilovers?
Old Jan 12, 2009 | 09:45 PM
EL-EE-ES's Avatar
it all depends on how low you want to go...it is recomended that if you go with springs that you go ahead and upgrade the shocks. most lowering springs have a higher spring rate and they compress the shocks piston more than stock springs, thus giving you more of a chance to blow them. for coilovers you get the ability to adjust how low you want the car to be. spring/shock combo are a bit cheaper than coilovers.
it is recomended that you get rear camber kits and toe bolts
depending how low your fronts are you may need front camber arms
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
