Problems related to wheel bearing and hub
Old Jan 30, 2009 | 02:00 PM
Preston's Avatar
Hey Guys
I know many of you who has G with 40K or up miles probably had or has issue with loose feeling on your suspension or wheels. You probably thought it was your outer tie rods, shocks, springs, or tires, but I seriously think this is not the issue. I replaced my shocks, springs, rack/ pinion, and new set of tires last month. However, I still have the looseness. I took it to the dealer and mechanic re-torqued all the suspension nuts and bolts, and he stated that nothing was loose or damaged. Based on my reserach, I think it is related to wheel bearing and hub issue.
If anyone had similar experiences, pls share in this thread
Problem:
vibration, wobbles, or loose feel coming from front wheels whenever car runs over ridge. The impact from this causing inside cabin to shake. Car feels ok w/ minimal vibration (almost none, but feel slight vibration from my gas paddle) when I drive on smooth road.
Also, this may be a dumb question, but is there a difference b/t ball bearing and wheel bearing??
thanks guys
Old Feb 2, 2009 | 03:17 AM
Paul35's Avatar
Originally Posted by Preston
Hey Guys
Problem:
thanks guys
I always felt this after I bought my car. I thought the reason was that its japanese. Had an audi before and never fell so bad.
Old Feb 2, 2009 | 04:15 AM
Joaquin03's Avatar
Staff ALUMNI
See here... I've shared my experience in this matter.
https://g35driver.com/forums/brakes-...ring-pics.html
Old Feb 2, 2009 | 04:32 PM
Paul35's Avatar
Wow that looks grimey! Ok so after reading your thread, I dont think my problem is vibration related. I think its more suspension related. I definitely need a tighter suspension.
Old Feb 18, 2009 | 03:38 PM
kyochon818's Avatar
I have a loud rotational vibration sound coming from the front driver's side of the wheel. I think I have an issue with my wheel bearing. I was thinking about buying an aftermarket hub & bearing from TIMKEN and taking it local. Can I trust TIMKEN products? or should I buy original? (I appreciate any advice).
Old Feb 18, 2009 | 03:44 PM
diablo1356's Avatar
the wheel bearing/hub issue is covered under your powertrain warranty. just take it to the dealer
Old Feb 18, 2009 | 08:27 PM
kyochon818's Avatar
My car has 100,000 miles. I don't think I'm under warranty anymore.
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
