how much camber adjustment from factory cam bolts?
Old Feb 15, 2009 | 09:16 PM
Texasscout's Avatar
I wouldn't expect more than +/- 1 degree of change.
Old Feb 15, 2009 | 09:22 PM
SDGeneralCounsel's Avatar
Originally Posted by Matthew121
hello guys, I just ordered a set of greddy type s coils, I am plan to lower around 1.75 fr and 1.5 r I know I should get rear camber arms, but I am wondering how close to stock specs (-1.8 iirc) I can get the rear camber with the stock cam bolts
any help would be nice,
thanks guys!
I have SPL A arms and SPC rear arms. My alignment is at perfect stock specs...., so it is very possible. You need not only rear chamber arms but also front A arms as well if you are going with coilovers.
If you are using the stock equipment expect to at least be 2 degrees off all around
Old Feb 16, 2009 | 03:50 AM
Matthew121's Avatar
thanks for the helpful info guys!
Old Feb 16, 2009 | 12:27 PM
eurodre's Avatar
well what the shop that i took it at did was he played around with it and was able to make the toe to spec but the camber wus just in the HIGH negative 2's, get the toe bolts, 35 bux from spc
Old Feb 16, 2009 | 09:41 PM
OCG35's Avatar
on Eibach pro (moderate drop 1.5") my OEM rear was able to get get into spec... however, I suspect going lower will require aftermarket - I picked up Sportlines (2+") and ordered rear camber and toe kit just in case.
Old Feb 16, 2009 | 09:57 PM
eurodre's Avatar
of COURSE ull need afermarket stuff
Old Feb 16, 2009 | 10:03 PM
OCG35's Avatar
me, or the OP?... OP is dropping 1.5 in the rear - I didnt need aftermarket for 1.5 in rear.
more than that = probably
Old Feb 16, 2009 | 10:06 PM
eurodre's Avatar
well im saying If u go lower then u WILl need aftermarket
Old Feb 16, 2009 | 10:08 PM
CandlestickPark's Avatar
ill Sedan
Sweeeet, cant wait to see your ride's new stance.
Old Feb 16, 2009 | 10:10 PM
O HELLA OEM's Avatar
im getting tein cs in about a week..i only plan on dropping the front 1 inch and the rear about .7-.9...do i need camber kit and toe bolts?!
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
NohoG35revup
Aug 22, 2015 12:13 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
