Stillen Sway Bar Bushings
Old Feb 24, 2009 | 01:12 AM
allstockg35's Avatar
I am planning on ordering the prothane bushings but I notice that the Stillen sways are 35mm front/22mm rear and the prothane bushings are 34mm / 21mm like stock. Will this be ok since the Stillen sway bars are suppose to use the factory bushings anyways or should I find the right size bushings for the sways?
Old Feb 24, 2009 | 12:46 PM
EGDgyDor's Avatar
Prothane bushings worked fine for me
I just put Stillen sways and prohtane bushings (from Summit Racing) on my 03 sedan and they work fine. I also put the supersticky lubricant on both sides of the bushings because that's the way the stock ones looked. I had read somewhere that the poly bushings transmit harsh vibrations, so in a fit of shadetree engineering, I made gaskets out of 1/8" fiber-rubber sheet and put under the sway bar mounts. I have no idea if this works, but there was no downside to the install except for a little more chop on the worst expansion joints and potholes. I have both bars set in the middle holes, but I plan to move the fronts to the lowest setting to improve the ride and slightly kick up the oversteer. Overall I am very pleased with the new sways; I am enjoying the control and flat cornering. Next on my list are Eibach Pro springs for a 1" drop and Tokio D spec struts. Good Luck!
Old Feb 24, 2009 | 01:38 PM
BrianlG35C's Avatar
Ohio G Club Member
I was also told they would fit, so I ordered them. We'll see.
Old Feb 25, 2009 | 03:05 AM
Thanks guys, ordering them tonight.
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
