Do-it-yourself Pads
Old Feb 25, 2009 | 03:15 PM
Vvargas's Avatar
Do-it-yourself Pads
I am thinking of replacing the brakepads myself, but I am not sure if the G35s need a special rachetting tool to get it done? Does anyone know? and if they do need the tool where can I get it from?
Thank you.
Old Feb 25, 2009 | 03:17 PM
joedaddy1's Avatar
nothing special.. u might want a torque wrench..
Old Feb 25, 2009 | 03:26 PM
Texasscout's Avatar
The only special tool you need is a "C" clamp or disc brake caliper tool of the proper size.
Less than 10 bux at most auto stores.
I have changed mine 3 times already.
Old Feb 25, 2009 | 03:29 PM
Vvargas's Avatar
Thank you guys. Just ot make sure, do I need a tool to compress the caliper? and, does this apply to both front and rear breaks?? example: there are some cars you need to turn while compressing the caliper.
thanks!
Old Feb 25, 2009 | 06:16 PM
uf20wop's Avatar
thanks!
the c clamp is used to retract the caliper piston
Old Feb 26, 2009 | 05:00 PM
SVTCOBRA's Avatar
thanks!
You are correct. On my 240 you had to use an attachment on your rachet to turn the rears. I had to do this on my cobra too.....I think...
You do not need this on a G35.
You just use the old pad and compress it back in with a large C clamp.
Old Feb 26, 2009 | 05:39 PM
Texasscout's Avatar
Remember to use a good quallity pad, I had no idea how cheap they were until I found them at the grocery store....
They don't seem to last very long, but I've got real good at poking them in with a screwdriver.
Old Feb 28, 2009 | 12:47 PM
JD_AND_DA_G_RIDE's Avatar
pads
You sure it was just the screwdriver you were using?? Ha..ha..your post was hillarious.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
