Brake Rotors & Pads for Daily Driver - Don't need Track grade, but want Quality
Can anyone throw me some suggestions for Front Rotors and Pads for my '04 G35 AT Sedan? I don't need a crazy track set up, but I don't want garbage either. Help me find something between running to Autozone and a $3000 Racing upgrade.
Dealer tried to hit my wife for $600 for Hawk (don't know what grade) pads and unknown rotors (fronts only).
Thanks,
I did poke around in there and even sent out a few PMs... But most of what is listed in there is BBKs, Caliper upgrades, and higher end stuff.
I appreciate the response.
While I agree the OEM stuff sure did stop the car, I'm surprised to see this as a recommendation. The cost of buying OEM stuff will probably exceed many of the performace aftermarket stuff. That, and even my local dealer won't use the OEM rotors unless its a warranty claim (did that once for me early on).
This is what I'm getting tomorrow:
http://www.z1motorsports.com/350_g35...oducts_id=2240
Z1 Brake Upgrade Package 350z/G35 (Base)
Z1 Motorsports stock sized brake upgrade package for 2003+ 350Z or G35 equipped with the standard base brake package.
This kit will take your stock brake system to the next level. If you are looking to upgrade your brakes but don't want to spend thousands on the many big brake kits available this is the kit for you!
This kit includes:
- ATE Super Blue Racing High Performance Brake Fluid for coping with the extreme demands posed by motor racing. Thanks to its outstanding wet boiling point, it has highest safety reserves. It is used in motor racing by leading car makes. Dry boiling point 280 degrees C (535F). Wet boiling point 200 degrees C (392F). Exceeds all DOT4 standards. 1 liter container. Super Blue High Performance Brake Fluid is standard in this pakage, however you may chose ATE 200 High Performance Brake Fluid or Motul RBF in the box below.
- All Four X Drilled and Slotted Rotors dissipate heat away from the rotors to reduce warping Zinc plated to prevent corrosion and increase life. Double disc grinding ensures parallelism. Mill balanced (withing 150 g-cm) to prevent vibration. Cross drilled to reduce weight
- Stainless Steel Braided Brake lines (All Four) Serious race car owners have used flexible brake hoses of extruded TeflonTM for decades. They are protected against abrasion and swelling by a sheath of tightly braided stainless steel wire. The resistance to "line swell" both improves the firmness or "feel" of the brake pedal and reduces the time required for effective pressure to reach the brakes and begin to slow the car.
- Hawk HPS Brake Pads (For All Four Calipers) Hawk Performance HPS pads offer 20-40% more stopping power and higher resistance to brake fade than most original equipment or standard replacement pads. This makes them more responsive and durable than most standard original brakes. Hawk HPS pads are standard, other options are available in the drop down menu below.
350Z and G35 brake upgrade packages are in stock at Z1 Motorsports ready for shipment or installation.
Please specify the year of your car below as the base brakes on the 2006+ models are larger in front. $575.00
I've been running R1concepts rotors with hawk hps pads for about 43k miles. I got all 4 rotors for about 140 bucks and they are still in great shape. Can't remember how much I paid for the pads but I bought them because they were highly recommended here. I'll probably try some project mu pads next. I really don't like the color of the dust the hawk pads leave.
Check out Centric Premium rotors (high quality, very reasonably priced, and Centric owns Stoptech) from g35parts.com or http://www.zeckhausen.com/Infiniti/G35-1.htm. I would pair with OEM pads for best cold stopping performance. Hawk HPS pads resist fade well, but are terrible on cold stops and in the rain.
Rotor/Pad suggestion....!
There's nothing wrong with OEM rotors but I'd use HAWK HP pads because
they have twice the life of factory pads. Plus, these pads leave very little
brake dust which we all enjoy....
Give Tony a call at Riverside Infiniti
he gives Driver members great discounts on parts 1-800-919-8130.
Gary
Give Tony a call at Riverside Infinitihe gives Driver members great discounts on parts 1-800-919-8130.
Gary
No need for drilling and slotting on the street - in fact it degrades thermal handling capability with less rotor mass. Stick with solid blanks for the street, unless it's purely for the bling factor.
