Suspension help! once again
Old Mar 12, 2009 | 10:47 PM
w1nkst4's Avatar
I searched around a bit and found that alot of members had the same problem as me but no one has replied the solution.
I installed JIC Flt-ar coilovers about a month again. I been gettin a litte rattle on the rears when i go slowly in wavy roads. Is there a solution to this?
Now, my fronts also act up. Right when I accelerate after a complete stop, theres a pop noise. When i turn i can also hear a pop noise. I have no idea what these noises are
Can someone please help me with these problems? Its starting to get annoying
Old Mar 12, 2009 | 10:50 PM
O HELLA OEM's Avatar
i have tein cs coils and when i go over bumps my rear passenger side shock makes a wierd noise..but i went to the shop that installed my coils and he said my shock may be blown..
but ive heard with any aftermarket suspension you'll get squeaks and shiet
ppl also say that coils are meant for the track b/c the surface is smooth ..
Old Mar 12, 2009 | 10:56 PM
w1nkst4's Avatar
I'm sure that the shocks arent blown because you will know for sure once your shocks are blown.
I read on the forums that there a screw that may be loose? I believe the noise is coming from where the spring is being held up. maybe where the metal is contacting one another but im not sure.
Im curious about my fronts because he never did that before til today and i read up on it. Is it cause of the endlinks that i saw was a problem as well? does it cause a pop noise?
Old Mar 13, 2009 | 11:15 AM
w1nkst4's Avatar
no one has any solution? =(
Old Mar 13, 2009 | 01:08 PM
Frankieg35's Avatar
I've heard that the sweybar endlinks go bad and make a squeeky metal rubbing noise..I think that's what's wrong with mine..
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
