Does new rotor need to resurface before install?
Notices
Check out the G35Driver Tire/Rim Calculator
Apr 4, 2009 | 09:26 PM
BuckeyeInMI
Nov 2008
Northern Lower Michigan
Because the OP has a Sedan?
At least that's probably why it's here. Of course that doesn't explain why it isn't in the Brake section.
BuckeyeInMI
Find all posts by BuckeyeInMI
jsimonk's g35 sedan progress thread
jsimonk
03:49 PM
Cryo Treated Rotors - Science or Snake Oil
Jiggerjuice
09:00 AM
Need advice: brakes are not working right
miata007
04:36 PM
OK So What's Nex?!!!
EnCr1pt3d
03:35 AM
Rotor bad or not?
RedBaronK
03:19 PM
Tags
2007
altima
angeles
coupe
film
g35
install
installing
los
protective
remove
replace
resurface
rotor
rotors
Back to Subforum
View Next Unread
DropZone Springs
10:38 PM
