Brake Components
Old Apr 5, 2009 | 01:40 PM
VstyLe09's Avatar
Brakes Brake Components
Hey, i couldn't find anything with search so i was wondering if you guys knew if the brake components (eg. brake calipers or the piston caliper) are covered under warranty?
Old Apr 5, 2009 | 02:32 PM
uf20wop's Avatar
the caliper and the pistons most likely are
the pads and rotors, obviously not
Old Apr 6, 2009 | 07:08 AM
Buzz Killington's Avatar
From: Intergalactic proton powered electrical tentacled advertising droids!!!
Caliper, pistons, master cylinder, abs components, lines, etc... Basically the mechanical parts would be covered, ( unless there is damage, modification or abuse ) Don't expect pad, fluid, or rotors to be covered... They're wear items.
Old Apr 6, 2009 | 08:38 AM
VstyLe09's Avatar
so i was was to take it in should i put the old pads back on or leave the ones i bought from autozone?
Old Apr 6, 2009 | 09:31 AM
EL-EE-ES's Avatar
whats the problem?
Old Apr 6, 2009 | 10:24 AM
VstyLe09's Avatar
well i believe my passenger caliper is seized.
Old Apr 6, 2009 | 11:29 AM
5150DS's Avatar
Leave what you have on. They cannot require you to buy their parts for maintenance.
Old Apr 6, 2009 | 11:47 AM
EL-EE-ES's Avatar
They would have to prove that the pads caused the caliper to seize...
Old Apr 6, 2009 | 04:31 PM
VstyLe09's Avatar
maybe bringin in the old pads and the pads i have on now will be better. since i just changed it yesterday there can be a change in the new pads already if it was seized and just show them the old ones.
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
alinero718
Sep 27, 2015 09:35 PM
vamarris
Sep 26, 2015 12:56 PM
