stiff rear shocks/ more travel?
Old Apr 9, 2009 | 07:22 PM
Gsedan35's Avatar
Originally Posted by 04-6speed-sedan
question; will the 350 shocks/struts mount the same as my oem?
Yes, 100% the same.
Old Apr 10, 2009 | 01:54 PM
Gsedan35's Avatar
are they any stiffer than stock?
Koni's in the rear, will not solve your problem.
Numbers are pulled from shock dyno file's I have. Sorry, I haven't had a reason to dyno oem sedan sport shocks, don't think I ever will.
Rebound stiffness shown in lbs/inches per second
Koni rear
1 ips 51lbs
2 ips 104lbs
3 ips 131
oem rear 350Z revised (softer on rebound vs the Koni sport shown above)
1 ips 36lbs
2 ips 79lbs
3 ips 116lbs
Compression stiffness shown in lbs/inches per second
Koni rear
1 ips 42lbs
2 ips 58lbs
3 ips 78lbs
oem rear 350Z revised (stiffer on compression vs the Koni sport shown above)
1 ips 68lbs
2 ips 91lbs
3 ips 109lbs
Old Apr 10, 2009 | 02:06 PM
Gsedan35's Avatar
Another example of when more stiffness results in bounce and freeway porposing
Two shocks are shown.
Both of them have the exact same bump or compression stiffness. Notice however that the blue line at the bottom show's that shock has greater rebound stiffness. Greater control means better ride quality right? Not in this case, your looking at shock dyno's for revised and unrevised oem rear 350Z shocks. Even though the revised shock is controling a 25% stiffer spring, it uses less rebound and deliver's a lot less bounce and porposing.
Old Apr 15, 2009 | 11:10 PM
04-6speed-sedan's Avatar
hey so i just put koni adjustable shocks in the rear only on a medium soft setting and my car not only rides way smoother but handles much better. im going to put fronts on soon its just the rear was way bouncy before... thx for the input.
Old Apr 16, 2009 | 10:26 PM
Gsedan35's Avatar
Which tells me your shocks oem shocks much have been in pretty bad shape.
Setting them on med is higher then you should set them based on the spring rates your running.
Luisgalvan33
Jul 19, 2018 08:16 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
GeeStatus
Aug 17, 2015 04:59 PM
Karnicle
Jul 23, 2015 05:08 AM
