Very Loud Braking Noies at Lower Speeds?
Old Apr 8, 2009 | 09:42 AM
I2icky's Avatar
I just bought a 2005 G35 coupe and I noticed when ever Im slowing down from a medium to high speed, the car starts making loud noises as I am slowing down. It sounds like its coming from the front and it sounds similar to what happens when a truck or airplane slows down. Is this normal for g35s?
Old Apr 8, 2009 | 10:23 AM
uf20wop's Avatar
check the inside of your tires, they're probably chopped
either that or you need anti squeal on the pads
i'm not sure what sound youre describing
Old Apr 8, 2009 | 10:54 AM
I2icky's Avatar
Its like a very deep howling noise. Like what you might hear when an industry truck pulls up next to you.
It sounds like its coming from the front.
Old Apr 8, 2009 | 11:07 AM
twin001's Avatar
maybe you have thrust reversers on your car
really though, have your brakes looked at. You may need new rotors/pads.
Old Apr 8, 2009 | 01:28 PM
uf20wop's Avatar
check the inside of your front tires, they're probably chopped
Old Apr 9, 2009 | 04:07 PM
Q45tech's Avatar
Chopped = heel toe feathered
Old Apr 9, 2009 | 04:11 PM
LaConic2's Avatar
+1...
i had similar problems..had my supsension,brakes checked..3 good mechs.no visible mechanical problems - bearings, rods.pads..rotors...
butttt they did notice the "chopped" feathered thread on the inside tires...
so im assuming its that..
its worse now too..LOL...or they said "breaking" while turning.
i must do alot of heel toe driving.LOL
but def. get it checked out, atleast u can get an idea before they rape u on some stuff u dont really need.
Old Apr 10, 2009 | 12:13 AM
I2icky's Avatar
What do chopped tires look like? i cant find much about them on google. This is my first time hearing this kind of terminology.
I also noticed that the sound usually occurs around the 20mph range. Below that and the sound goes away, and above 20 its still heard but not definitely not as loud.
Old Apr 10, 2009 | 09:00 AM
uf20wop's Avatar
kinda like the right side, but worse
i'm pretty sure the sound you've been describing is caused by the inside of the tires bearing really worn down
rezendvous420
May 31, 2020 01:26 PM
mtlruss
Dec 20, 2015 01:51 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
ScraggleRock
Aug 11, 2015 10:16 PM
ddietz97
Jul 26, 2015 06:16 PM
