Fitment of Richie (NRG) Strut Bar on Sedan?
Old Apr 9, 2009 | 10:11 PM
ProfanityPete's Avatar
Hey, I'm just curious as to if the fitment issue on this strut bar carries to the sedan, and or if it is fixed. I've searched, but can't find anything, and I kind of want to find a strut bar that will fit over a 5/16 spacer, and a CF engine cover, and I'm thinking about picking this up.
Also, if anyone knows where I can get some CF battery covers, let me know. Been searching for them for quite a while.
Old Apr 9, 2009 | 11:10 PM
G35Papa's Avatar
The Richie v2 is suppose to not have the fitment issue of the hood hitting the bar. I have the latest NRG strut bar which is the same bar and I still had to elongate the holes more so the hood didn't hit it. Either one will clear the 5/16 spacer and an engine cover.
The CF covers come up on eBay from time to time.
Old Apr 9, 2009 | 11:20 PM
CandlestickPark's Avatar
ill Sedan
^+1, no fitment issues for me with the NRG strut bar and I have a 5/16th spacer. Never had any issues with it rubbing on the hood.
Then I got a new suspension setup and had to modify the brackets to fit with my BC Racing coils.
Old Apr 9, 2009 | 11:28 PM
Thanks, think I might go with one of these bars... not sure yet though
Old Apr 9, 2009 | 11:29 PM
Jeff92se's Avatar
Red Card Crew
I have the 1st version and no problems. But I had to bend the brackets so i could adjust my Konis.
Old pic. I have my V5 crawford on now and it doesn't rub
Old Apr 10, 2009 | 02:01 AM
Viscous's Avatar
How can you guys tell if it's rubbing or not? I have the V1 bar and it's over the engine cover and a 5/16 spacer, but there's no way I have been able to tell if it was really rubbing the hood once closed. There aren't any strange noises or bulges in the hood of course...
Old Apr 10, 2009 | 02:03 AM
G35Papa's Avatar
My hood was lifting up in the corners at the top closest to the windshield.
Old Apr 10, 2009 | 03:50 AM
Sacch's Avatar
Is there a difference in the fitment for the G35X?
Old Apr 10, 2009 | 09:05 AM
Viscous's Avatar
Ah thanks, well I guess that's a pretty obvious indicator. In that case, so far so good, although I do get paranoid that one day, if I hit a large bump, the entire bar would slide up on the brackets and deform the hood. That keeps me up at night, worries me more than my broke 401 portfolio. I think I need to see a psychologist.
Old Apr 10, 2009 | 12:22 PM
ill Sedan
You could also tell if its rubbing by checking to see if you have a scuff mark on the underside of your hood with a corresponding mark on the bar.
Old Apr 10, 2009 | 01:23 PM
G35Papa's Avatar
if you still have the heat pad thingy under your hood, you would get dirt/dust marks on the bar as well.
Old Apr 10, 2009 | 05:58 PM
jaydafunk's Avatar
i have the richie v2 w/ 5/16 spacer and the stock engine cover and i have no clearance issues.
Old Apr 10, 2009 | 07:18 PM
ill Sedan
Oh yeah, I should have mentioned that I took mine off when I installed the bar because I didn't want to get any marks on the bar from it (and the underside of the hood looks way better without it).
Old Apr 11, 2009 | 02:36 AM
clinthammer's Avatar
I've got the v2 with a MD 5/16 spacer and CF engine cover and the hood liner rubs very very slightly on the strut bar. Had this setup for over a year now!
Old Apr 11, 2009 | 09:16 AM
Alright, thanks everyone for the input, not sure if I want to pull the trigger on this yet or not... Pretty much just for aesthetics, right? I mean it provides a slight bit of support, but nothing crazy, or am I just crazy?
