Please Help: Squeaking Brakes!
Old Apr 15, 2009 | 05:01 PM
valid_1's Avatar
I have this "problem" when I am braking. i have brembo on my G35 '04 coupe and when i am coming to a stop my brakes squeak pretty loud. Its annoying and embarrassing at the same time.
i am pretty sure the brakes pads are good!
this might be a dumb question but is it possible to fit any other brand brake pads on Brembo sets?? and if yes, which ones do you guys suggest which are cost effective and dont leave dust or make too much noise?
thanks alot in advance.
Old Apr 15, 2009 | 05:04 PM
valid_1's Avatar
Just to add to that! the brakes squeak only on LOW speed! when i am about to stop on a red light on something and have my foot on the brakes lightly!
there is no vibration or noise at high speed!
Old Apr 21, 2009 | 01:16 PM
G35fromPA's Avatar
Assuming they are OEM Brembo pads with the shims on them, they are either 1) worn too low, or 2) in need of a bit of brake lube. I replaced my front Brembo pads myself in Nov. '07, put plenty of 3M Brake Lube on them and I haven't heard a peep out of them.
Old May 24, 2009 | 11:04 PM
BH818's Avatar
If u see that you still have brakes left on the pades, the way to fix the squeal is to use a air compressor and blow all the brake dust out. that always fixes it, trust me you dont even have to take the rims off just blow the dust out good
Old Aug 20, 2010 | 10:44 PM
doeboy's Avatar
I have the same problem, I guess I need to lube it up. Where and what exactly do I need to lube?
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
