350z Sway Bar/Suspension Question
Old May 2, 2009 | 02:41 PM
KevcoG35's Avatar
Originally Posted by SwivelHips
Now you just need a good exhaust.
I gotta get busy and put my Z stuff on one of these weekends.
Weather is finally turning decent, gotta get that on before the cruises start up!
Old Apr 28, 2011 | 06:20 AM
mysoda's Avatar
are the springs and shocks from sport coupe same as non sport coupe?
i have a sport sedan, will it be an upgrade if i change mine to full coupe shocks and springs?
Old Apr 28, 2011 | 06:21 AM
mysoda's Avatar
Old Apr 28, 2011 | 09:22 AM
Johnnyone's Avatar
At first i was like why the heck is Ash asking a question like this but then i realized it was from 09, lolz...
^ idk if coupe non sport and a sport springs and shocks are the same but i do know that it will drop your sedan .5 inch. What are you trying to accompish?
Old Apr 28, 2011 | 10:46 AM
NFSP G35's Avatar
? = 2B || !2B
No, the sport / non sport coupes have different springs and shocks (in the back at least)
Old Apr 28, 2011 | 03:13 PM
mysoda's Avatar
how do i know if they are sport or non sports for the coupe?? i know for sedan the color of the shock tell you if they are sport or not.
what is the difference in term of spring rates??
i was thinking the coupe shocks and spring will lower my ride a little bit also give a little bit stiffer than my sedan sports suspension.
Old Apr 28, 2011 | 03:16 PM
NFSP G35's Avatar
? = 2B || !2B
^Coupe sport rear springs/shocks are the same as 350Z "revised" springs/shocks (provided the coupe is new enough)
If the coupe had oem 19's, it's a sport. If it's a 6MT, it's a sport.
The easiest way to check if all you have to go off of is the springs/shocks themselves, is that the spring will have two red dots and a purple dot.
Non-sport has three red dots IIRC.
Old Apr 28, 2011 | 06:27 PM
mysoda's Avatar
ok, i will go check if the spring are sports. t red dots and a purple dot. got it. thanks.
Old Apr 29, 2011 | 03:06 AM
mysoda's Avatar
yes, i check they have 2 red dots and a purple dot on them. so if i put them on, it will be stiffer than original sport sedan suspension?
also i know it will lower my car about .5inch. do i need a camber kit?
Old Apr 29, 2011 | 11:34 AM
NFSP G35's Avatar
? = 2B || !2B
^Yes it will be stiffer, but only slightly, and in a good way (like, less bouncy/squishy, not bone-jarring by a long shot)
It may lower your car as much as 1"
No, you don't need a camber kit, just an alignment... might want to have them use 350Z specs.
Old Apr 30, 2011 | 02:52 AM
mysoda's Avatar
lower 1"??? no alignment required???wow.. that's pretty awesome if i am putting the coupe 18" on..
Old Apr 30, 2011 | 08:42 AM
NFSP G35's Avatar
? = 2B || !2B
^No.... you DO need an alignment, just not a camber kit.
Old May 1, 2011 | 05:48 AM
mysoda's Avatar
lol..typing errors
rezendvous420
May 31, 2020 01:26 PM
Th611
Oct 27, 2015 03:48 PM
NohoG35revup
Aug 22, 2015 12:13 PM
linedr89
Aug 17, 2015 05:11 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
